samsung syncmaster 715v
  • ajd15
    • Oct 2011
    • 12
    • united states
    screen is black when I use a strong light there is no image of any kind. The power light is always on you can't turn it off it stays green until you unplug the unit.All caps appear good. This is new to me. Where do I start?
    ajd15
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: samsung syncmaster 715v
    Please update your profile with country and mains voltage.
    We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
    Examples of what is needed
    https://www.badcaps.net/forum/attach...7&d=1280167246
    https://www.badcaps.net/forum/attach...6&d=1280167246
    https://www.badcaps.net/forum/attach...4&d=1280167246
    It will be useful if you can say a bit about yourself - skills tools etc.
    • ajd15
      • Oct 2011
      • 12
      • united states
      updated my info but my scanner is down at the moment.probably need a dew one.
      • ajd15
        • Oct 2011
        • 12
        • united states
        Also looks like I need a NEW speller
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          We are a bit stuck then as I have no idea what you are looking at.
          Can you find another model with the same power supply - search using the board number. Post the board number and a link if you find it on line.
          • ajd15
            • Oct 2011
            • 12
            • united states
            board number is MJ19BS. also after replacing the 5 caps ,not the big one. I was no able to turn the green light on and off with the switch. However the screen still is black. I substituted the bulbs with a known good set that I have and they didn't come on..
            ajd15
            • ajd15
              • Oct 2011
              • 12
              • united states
              My spelling is getting worse. I am now able to turn the green light on and off.
              ajd15
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                You can just Edit your post within 1hr of creating - but dont change anything substantial in case someone has read it - they wont go back and see the correction.
                EDIT
                On google images there are a lot of boards come up - find one that looks
                nearest to yours and post a link to it.
                • ajd15
                  • Oct 2011
                  • 12
                  • united states
                  ttp://www.badcaps.net/forum/attachment.php?attachmentid=58380&stc=1&d=1361225262
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    You are beginning to annoy me now!
                      09-07-2024, 05:50 AM
                    • soopacrucial
                      Samsung Syncmaster 740BF repair
                      by soopacrucial
                      Hi folks,
                      I'm new here and was wondering whether you might be kind enough to give me some advice on troubleshooting the following problem:
                      Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...
                      10-29-2024, 02:40 PM
                    • Kaar3l
                      Samsung QLED QE65Q7FNAT only standby light
                      by Kaar3l
                      TV: Samsung QLED QE65Q7FNAT
                      PSU: BN4400940A
                      MB: BN94-12832K
                      I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                      09-24-2024, 01:35 PM
                    • marcinq
                      Samsung UE60KS7000 No Standby Light
                      by marcinq
                      I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
                      I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
                      05-26-2025, 11:36 AM
                    • DXseekerMO
                      Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be on
                      by DXseekerMO
                      Hello everyone!
                      Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
                      Symptoms:
                      1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
                      2) TV does not appear to turn on
                      3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
                      4) "Power on" terminal on Power Supply has 3.26v
                      5) "A13V" terminals have 12.9v
                      6) Stand-by test jumper on Power Supply has 12.9V
                      7) Optical audio jack on Main Board illuminates
                      8) With stand-by...
                      06-09-2021, 12:19 AM
