troubleshooting DAC 19M008 power supply
  • mikeh1
    • Feb 2013
    • 37
    • usa
    I found this site while searching for troubleshooting tips for a Viewsonic VA1912wb3 monitor with a DAC 19M008 power supply, that doesn't seem to power up; no green power light and no picture. I have replaced some bulging Capxon caps on the power supply board, 3 of the 220uf/25v and 2 of the 1000uf/25v. I found and removed a solder blob shorting two of the leads of one of the 8 pin DIP ICs. I also resoldered the connections to the two transformers, they looked a bit gray.
    Are there any other parts that I should replace?
  • sabre504
    • May 2010
    • 449
    • United Kingdom
    Re: troubleshooting DAC 19M008 power supply
    First check that you have power at the main cap (the 400v 120uf) set to DC and report voltage .
    Then check the output pins on the board also report findings if you have not already checked these
    • sabre504
      • May 2010
      • 449
      • United Kingdom
      If you are not getting correct voltages at the secondary output
      Check fuses on the back of the power board F102 and F200 (pic 1)
      If you have correct voltages chsck voltage regulators on the video board (pic 2)
      I have posted pics as a guide your boards may be diffrent we need pictures really
      • mikeh1
        • Feb 2013
        • 37
        • usa
        I was able to check both fuses, both are OK. I'm not very familiar with circuit design, but I know how to work a VOM. How would I go about testing the 400v 120uf cap? (It is a Capxon, but it is not bulged out like the ones I replaced.)
        • mikeh1
          • Feb 2013
          • 37
          • usa
          I just checked the 400v 120uf cap with a VOM (no power to board), no continuity, and when testing for DC volts shows 2V DC. Does this mean that this cap is OK?
          • sabre504
            • May 2010
            • 449
            • United Kingdom
            You will have to apply mains power to the board ,
            Set your meter to DC depending on what the increments are it must be set above 400v (ie 600-750-1000).
            Place red probe on the positive leg and black on the negative leg (marked with white stripe)
            Careful high voltage report reading .
            This is not to test the cap itself but to check that it is getting the correct voltage to run the board and the result will help others help you where to test next
            • mikeh1
              • Feb 2013
              • 37
              • usa
              I'm getting 200v DC at the cap
              • sabre504
                • May 2010
                • 449
                • United Kingdom
                What is your mains voltage
                • mikeh1
                  • Feb 2013
                  • 37
                  • usa
                  120 VAC
                  The multimeter I'm using has a setting on the DC side for 250v/1000v, and a separate socket for the 1000v setting. Using it that way, the cap read 50v on the 250v scale.(there is no 1000v scale on the meter)
                  I'm going to get a newer multimeter so I can more accurately read the voltage
                  • sabre504
                    • May 2010
                    • 449
                    • United Kingdom
                    You should be getting a reading of approx 168v
                    120 x 1.4
                    But try the pins on the output socket and see what readings you get
                    Voltages should be marked on the board under the pins
                    • mikeh1
                      • Feb 2013
                      • 37
                      • usa
                      with new meter got 165.5 vDC
                      • mikeh1
                        • Feb 2013
                        • 37
                        • usa
                        120 x 1.4
                        do I measure each pair of pins or from each pin to ground?
                        • sabre504
                          • May 2010
                          • 449
                          • United Kingdom
                          For now you just want to test the 13.8v pin and the 5v pins
                          • mikeh1
                            • Feb 2013
                            • 37
                            • usa
                            the two 13.8v pins measure 14.2v and the 5v pins measure 0v
                            • sabre504
                              • May 2010
                              • 449
                              • United Kingdom
                              Test each side of the fuse F102 to make sure there is no voltage
                              If no voltage then we are at the point that we are going to need actual pics of your board
                              • mikeh1
                                • Feb 2013
                                • 37
                                • usa
                                getting 4.75v across the fuse F102
                                • sabre504
                                  • May 2010
                                  • 449
                                  • United Kingdom
                                  Then you should have the same at the pin
                                  • mikeh1
                                    • Feb 2013
                                    • 37
                                    • usa
                                    do I test across the two 5v pins or separately test each one to ground?
                                    • sabre504
                                      • May 2010
                                      • 449
                                      • United Kingdom
                                      Try each pin to ground
                                      • mikeh1
                                        • Feb 2013
                                        • 37
                                        • usa
                                        looks like the fuse F102 is bad, with the new meter I'm getting a reading of 180 ohms
                                        I was getting 5v on the inboard side of the fuse and nothing on the other side, so I rechecked the fuse. One side of the fuse also has a small solder blob that's not smooth, like it heated up the solder a bit.
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                        • shamsudeen
                                          Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                          by shamsudeen
                                          Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                          I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                          i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                          Today, 07:14 AM
                                        • dragon3x
                                          >>> Troubleshooting Delta Power MAX 500ATX ATX power supply
                                          by dragon3x
                                          Hi, this is for troubleshooting and, hopefully, repairing a Delta Power psu
                                          that is still quite new, as it worked OK for some months until it failed.
                                          At the time I was not into power supply electronics; it was put
                                          aside and a new power supply installed inside the computer. Also at the time
                                          power supplies were half the price of today's.
                                          On the PCB there are a D339 and 7500B chips.
                                          I have found that schematics with these 2 chips (see included file).
                                          Does it represent the actual circuit of the MAX-500ATX, I cannot tell.
                                          Some measurements,...
                                          06-05-2024, 03:34 PM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
