Medion 1998 OF no picture after suspend mode
  • gonzo0815
    • Feb 2006
    • 1600
    Today i have cleaned my junkpile, and i found this nice 19" crt from Medion. It is not mutch used, but there is an anoying problem.
    If the crt is on for about a half to one hour the picture goes off, but the green power LED is still on. After several hours w/o power it is working again.
    It is the same if i suspend the monitor, it dosn`t switch to the stand by or suspend mode, instead the green power LED remains green. It is the same if the pc is off, a normal CRT should went in to suspend mode and the LED should turne yellow, but if the failure occure, this crt don`t do that.
    After resoldering all the mechanically or by temperature stressed solder joints, wich fixed for me several Medion CRT`s there was no succes. I replaced some suspected caps, but with no succes again.
    I discovered, that there is an relay, near the input rectifier bridge. If the failure occurs, this relay don`t switch on. But it dosn't help to switch this relay on by hand (i.e. shorting the PNP driver transistors base to ground).
    If the crt is bared, the occurance of the problem is reduced.
    The main SMPS is working, and the High voltage section is working too.
    For me it seems that there is somwehere an badcap on the s/b controler section, but i duno wich controler does handle it. There are about 3 chips, the main SMPS controler, a Daewoo uControler wich controls the mentioned relay, but the caps there seems to be ok.And then there is an Atmel uControler near the front pannel, assuming that this is responsible for OSD.
    Up to now i will try to replace severall 10uF HEC caps near the Deawhoo uControler, but this is only the last effort. The whole crt is full of badcaps like HEC, Elite etc.
    This crt is not bad otherwiese, thus i hesistate to trash em, as it is obviousely< not realy damaged....
    If anyone hafe suggestion where to look it would be apreciated.
    The power consumption in failure mode is about 70w, so i assume that all major systems are working.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Medion 1998 OF no picture after suspend mode
    you have a thermal intermittant.
    btw the relay is for degaussing only.
    get some freeze mist and a hairdryer.
    • gonzo0815
      • Feb 2006
      • 1600
      What exactly do you mean with thermal intermittant?
      Do you mean any defekt wich is temperature related e.g. bad solder joint, badcaps or and semiconductor wich fail at a certain temperature?
      The icespray i had in mind, but unfortunately i was runing out of it. The hairdryer has no efekt whatsoever. Any way., i will buy a can of icespray and i should be able to find the defekt component.
      • gonzo0815
        • Feb 2006
        • 1600
        Finally i fixed that bugger. Sprayed a whole can of ice spray on it w/o any succes. But if i bent the whole PCB upwards, i got the screen back. I solldered nearly the whole PCB, untill i noticed that it was not the main PCB, but the signal cable going to this smaller PCB at the end of the tube. After carefully soldering the whole small PCB removing the glue on the singal cable conector, refiting and glueing back the damn bugger is no working fine. It kost me a considerably amount of time to find this anying factory failure. Any way, i am pleased to bring this monitor back to live, even at the very moment i was close to trash em.
        • VILE DISRUPTION
          • Jun 2006
          • 47
          Heh like me and the dvd player. No left channel sound. check "ALL" solder joints overlook the one at the left channel witch is soldered on the pcb pop as i pop the cover back on i hear something falling. the left channel plug has fallen inside. resolder it and i laugh about it to this day.
          Stats Reset Every Month.
          My Forums
          • gonzo0815
            • Feb 2006
            • 1600
            Yea man, thats are those things you only can laugh abouth and consider it as an plus in experience
            • yanz
              • Nov 2004
              • 910
              ya, you might do troubleshooting to no end. you have to have a good eyes and good mood
              otherwise you'll end up using the object you were trying to fix as a rifle object
              days are so short when you actually do something..
              • BlackBeetle
                MEDION AKOYA S15450 MD 63650 MSN: 30030203
                by BlackBeetle
                Hello, I have a problem with a Medion notebook.
                https://www.medion.com/de/service/pr...etail/30030203
                MEDION AKOYA S15450 (MD 63650) A-DE N MSN: 3003 0203 with Windows 10 64x
                The keyboard makes random entries and I don't seem to be the only one. Someone on this board has the same problem. I had BIOS version 207 installed and the BIOS version that Medion Support offers here as 209.
                https://community.medion.com/t5/Note.../104097/page/2
                Bios Version...
                08-09-2024, 05:50 PM
                MEDION AKOYA E2016 F AKOYA i3-6100 Specification for Upgrade or Repair
                This specification for the MEDION AKOYA E2016 F can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the AKOYA E2016 F boardview and AKOYA E2016 F schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for MEDION...
                09-12-2024, 02:20 PM
                MEDION ERAZER X67063 ERAZER i5-8400 Specification for Upgrade or Repair
                This specification for the MEDION ERAZER X67063 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ERAZER X67063 boardview and ERAZER X67063 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for MEDION...
                MEDION AKOYA P62005 AKOYA i5-8400 Specification for Upgrade or Repair
                This specification for the MEDION AKOYA P62005 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the AKOYA P62005 boardview and AKOYA P62005 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for MEDION...
                MEDION AKOYA P5218 F i5-6400 Specification for Upgrade or Repair
                This specification for the MEDION AKOYA P5218 F can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the AKOYA P5218 F boardview and AKOYA P5218 F schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for MEDION...
