Hp 1502
    Re: Hp 1502
    i'll give it another try tonight as I got stuck in the last bit as there was like a chip connected to the last frame and the screen.
    I'll try again tonight. I do have a faulty laptop which I can remove the bulbs from.
      Re: Hp 1502
      you may not need to remove the bulbs we can try an talk you through just using the whole panel- laptop bulbs are quite fragile.
        Re: Hp 1502
        ok.. i have managed to remove the bulbs successfully. now what next?
          Re: Hp 1502
          Bulbs from the laptop?
          Is the plug the same as on the monitor - if so just substitute it.
          Is the plug the same as on on the other monitors?
            Re: Hp 1502
            So, I have managed to dismantle the bulbs from this monitor and I also dismantled the bulbs from a dell monitor.
            The thing is that Dell use a different socket plug and it is a double bulb. Do I need to cut the wire and solder it to the HP's Plug or do they have some sort of holder?
              Re: Hp 1502
              Can you post pictures of the ends of the bulbs in the respective
              Threads - Just in case we cant see are the ends blackened or the wiring
              burnt
              EDIT post pics of the plugs as well
                Re: Hp 1502
                yes the ends are blackened. photos are coming
                  Re: Hp 1502
                  unfortunately i cant provide a picture of the hp bulbs as they are reflecting but attached please find a picture of the dell bulbs, dell sockets ( dual sockets ), hp socket (a big one)
                    Re: Hp 1502
                    I dont suppose you would be lucky enough to be able to get the metal pieces to com out of the plugs ( To save cutting the wires)
                      Re: Hp 1502
                      the holder of the bulbs are rubbery.... can those come out of that as I'm afraid to break it?
                        Re: Hp 1502
                        No dont try to get the Bulbs off the wires.
                        On the other ends can you get the metal pins to come out of the plugs?
                        I have just tried with an lg monitor and if you look at the end of the plugs
                        There MAY be two holes if you insert in a needle into the hole without the pin
                        and pull on the wire it MAY come out. Mine did
                          Re: Hp 1502
                          i had to cut the wires in order to work but anyways... so i had connected this bulb with the board and when powered it up the bulb turned on.
                          So now my question is, how can i fit this bulb into this monitor as it is different ( i.e. 2 bulbs going into one holder and I do need them to be separate and go into my holder.
                            Re: Hp 1502
                            Ok I dont know if they will separate - would be good if they did then you would still have a test bulb - If they both fit in the space where the one came out then perhaps try it like that for now until you see if you actually get a picture on the monitor.
                            Then if you dont it can still go back to where you got it from.
                              Re: Hp 1502
                              it can's fit as the Dell one has 2 bulbs as shown in the previous post, whereas the HP one's are single one's. i will try to take off the holder with the wires although i think that it is impossible.
                                Re: Hp 1502
                                Wish I could see what your doing - You are doing really well with the improvisation so far. Just checked your only 1 hour ahead - thought it would be at least 2 even though I visited Malta earlier in the year I forgot. We stayed in Sliema and travelled around on the public bus- it was great.
                                Im off to bed - busy day tomorrow.
                                  Re: Hp 1502
                                  I will try to do the experiment tonight and will let you know about it
                                  Have you ever came to Bugibba? There is where I live. The public bus service is not too convenient though hehe.
                                  In the meantime can you please help me with my other New monitor hehe?
                                    Re: Hp 1502
                                    Didnt get to Bugibba - went past the end of the road to it on the way to Gozo.
                                    Will look at the other post.
                                      Re: Hp 1502
                                      after replacing the bulbs with 2 good one's, the problem persisted
                                        Re: Hp 1502
                                        could it be a bad vga cable? if so it would be a problem as this is a fixed vga cable :S
                                          Re: Hp 1502
                                          well I have managed to fine a similar vga cable in an old crt. I have tried it in and now the backlight lights up, it shows going to sleep mode and the monitor's power led turns to amber.
                                          Any suggestions?
