VA1912wb issue
  • bjmaclac
    • Nov 2012
    VA1912wb issue
    My Viewsonic VA1912wb monitor has recently come up with the most annoying problem. The blue contrast/brightness dialogue box has appeared and - despite all efforts on my part - will not go away. The damned thing sits smack in the middle of the screen, while the "highlighter" bounces back and forth between the brightness and contrast buttons. All the manual buttons at the bottom front are okay; none of them appear to be stuck.
    I am not a "tecky"; and hope to hear of a non-technical solution to this problem.
    Otherwise, the monitor is in good working order.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: VA1912wb issue
    Moved from FAQ. Please don't post questions there.
    as for your problem, it sounds like a bad microswitch. you can confirm this by opening the LCD case and using a multimeter to see what that switch is doing. It it is indeed shorted, buy a replacement on digikey/mouser/newark and happy soldering.
    (if that is too tech of an answer, then get a new monitor or have a tech fix it. there is no other way)
    PS- You misspelled "Vancouver" in your location. If I were you, I'd fix that.
    sigpic
    (Insert witty quote here)
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Re: VA1912wb issue
      Here is the service manual
      page 7 onwards has detail of the button functions.
      When the osd is not on the screen try the factory reset for brightness/contrast then follow by the shortcut to lock the osd.
      Dont know if that will work but shouldnt do any harm.
      • DqMagetz
        Acer Nitro 5 AN515-54. displays on the external monitor and works fine, the issue is NO display on the internal screen
        by DqMagetz
        Good day!
        I have a customer's laptop — Acer Nitro 5 AN515-54 (EH5VF - LA-H501P). It has a display on the external monitor and it's working fine, but the issue is NO display on the internal screen. I already replaced the eDP cable and checked the LCD connector pins.
        Here are the voltage readings:
        • Input – 19V (stable)
        • +LCDVDD – 3.3V briefly, then drops to 0V
        • EDP_HPD – 3.3V briefly, then drops to 0V
        • PCH_BKL_PWM – 2.2–5V briefly, then drops to 0V
        • EC BKOFF# – 1.8V briefly, then drops to 0V
        • PANEL_OD_EN – 0.3V
        Is it possible that the EC chip is corrupted or damag...
        07-12-2025, 09:37 PM
      • wattage
        by wattage
        Hello Badcaps Community,
        07-13-2025, 04:41 PM
      • Rick_1234
        by Rick_1234
        Good evening, gentlemen.
        Things I tried
        06-22-2024, 04:44 PM
      • sew333
        Pc shutdown, monitor flickered with no signal after 10 seconds
        by sew333
        My pc:
        10850K stock 4800mhz stock Kraken X73 good temps
        2x16 GB DDR4 GSKILL 3000mhz XMP
        Seasonic Tx-850 Ultra Titanium
        Gigabyte Rtx 3090 Gaming OC
        Aorus Z490 Pro Gaming
        1 TB SSD
        4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
        Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
        Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
        Power...
        02-22-2022, 10:27 AM
      • FercHeliX
        LG 1510S Monitor Issue
        by FercHeliX
        Hi
        There's this old LG 1510S LCD Monitor that had 2 issues, one with inverter board and one with image display (mainboard maybe), the issue with the inverter was that when i turned it on it goes off after 1 or 2 secs. and the problem was with the tuner caps on inverter board, after i changed the caps monitor stays on but there's another problem that if I turn it on by the power button, no signal message does not show on the screen, but if I let it stay on and disconnect by the power cable and connect it again the no signal message will appear, and one more thing...the 12V power is 17V before...
        01-28-2022, 08:20 AM
