Troubleshooting Samsung 214T
  • ShankyMcStabber
    • Oct 2012
    • 5
    I have a Samsung 214T that went black on me a few weeks ago. After doing the flashlight test I saw the backlight was out.
    When I cracked the case open, I found that the 2 820uf 25v capacitors were busted. Rather than replace capacitors piecemeal, I went ahead and ordered a complete replacement set.
    After removing the old capacitors and putting in the new capacitors I hooked the monitor back up and the screen would only flash (less than half a second) and then go off (power light remained green). The flashlight test shows the monitor is showing the picture but the backlights are not on.
    Using my multimeter I tested across all 6 transformers feeding the backlight and they are all consistent with each other.
    Now here is the odd part. I disconnected the upper backlight and turned the monitor on. I got a picture for 2 seconds and then black. I then reconnected that backlight and disconnected the lower backlight and turned the monitor on. I again got a picture for 2 seconds and then back.
    To sum up (for the tl;dr crowd):
    Had bad caps, replaced them.
    Took multimeter to transformer, looks good.
    Both backlights connected, screen flashes with backlights on less than a second.
    One backlight connected, standard 2 seconds to black (doesn't matter which backlight)
    Anyone able to point me towards what might cause this problem?
  • Lumberjack777
    • Dec 2010
    • 464
    Re: Troubleshooting Samsung 214T
    Ok. We'll definitely need good quality pics of the front and back of the power board and the inverter board. Sounds like maybe when the 2 820uf 25v capacitors went out; they may have taken a component with them. Should be able to locate and get this fixed. Use "go advanced" with managed attachments. ~L-J-7~
    • mariushm
      • May 2011
      • 3799
      The 2 second interval is the default interval the controller sends pulses to the lights to ignite. If it still detects a lamp as not running, it turns itself off.
      So when testing with just a pair, it always shuts down because it does not detect lamps on the other pair.
      It's hard to determine that BOTH lights in a pair are running, because you often don't notice a decrease in brightness, the layers of materials in the panel are very good at spreading the light evenly across the panel.
      In your case, it's possible that one of the lamps in a pair is bad or one of the wires came loose so you probably have to carefully take off the metal cover of the panel and look directly at the lights to see if they light up.
      If one doesn't, then you have to gently pull those silicon terminals at the end and solder the wire that's loose.
      • ShankyMcStabber
        • Oct 2012
        • 5
        If that is the case, how come the I can always see the screen (for 2 seconds) when I disconnect either of the 2 CFFL connections but not if I actually have them all connected (aka normal operation).
        I've hosted the images off my photobucket account (to keep it at extra high quality).
          Check the resistance readings of each transformer, it should be around 980~990 Ohms. What were your readings.
          https://www.badcaps.net/forum/showth...468#post276468
          You will always get 2-second to black if ALL the lamps do not fire up and stay conducting, if the circuit detect open circuits if it does not see current flow through ALL the lamp (if one lamp is not connected) then it will shutdown the high voltage AFTER 3 seconds, that is why the lamp that is plugged in will flashes then turn off.
          You may need to make test lamp to verify the inverter function.
          http://s807.photobucket.com/albums/y...g%20old%20CFL/
          • ShankyMcStabber
            • Oct 2012
            • 5
            I will have to do the ohms testing tomorrow. I went to do the ohms testing again and my multimeter seems to have died somehow (when set to 2k ohms with the leads not connected it reads .947 and gives me odd readings like .498 when I try to measure across the transformers).
            I think my kids were playing with it again.
            • mariushm
              • May 2011
              • 3799
              Some multimeters have problems measuring resistance when combined with something inductive, like coils of transformers, inductors etc
              It might not be a issue with the meter.
              • jetadm123
                • 2169
                Maybe the multimeter battery needs changing?
                • ShankyMcStabber
                  • Oct 2012
                  • 5
                  Okay, I actually managed to get hold of a 2nd Samsung 214T.
                  The 2nd monitor had 4 blown caps but the display would flicker. So I took the inverter board from the 1st monitor and put it in the 2nd.
                  BINGO, I have 1 working monitor. Put the board from the 2nd monitor into the first and it insta-flashes.
                  Sounds to me like the CFFL have been killed on the 1st monitor. Sound about right?
                  • bluto
                    • Oct 2007
                    • 560
                    Yep it sounds like a classic 2 seconds to black problem. Although if I was in your shoes I would re-cap the second board just to be sure. The 214Ts are great monitors (I am staring at two right now). Someone here will probably want it to attempt a re-lamp or just for working parts. I would want it if I had not sold my third 214T that came with a cracked screen. It would be totally sweet to have three of them on my desk
                    • ShankyMcStabber
                      • Oct 2012
                      • 5
                      I actually use them in my Arcade Cabinets.
                      I won't get rid of the broken one. It is a source for parts if something other than the caps go.
                        09-07-2024, 05:50 AM
                        by momaka
                        03-15-2023, 10:17 PM
                      • max789
                        Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                        by max789
                        Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                        I made the following tests:
                        1. Disconnected the main board from Power Board = backlight works.
                        2. Connected the main board and disconnected the T-Con = backlights does not work.
                        So I ordered a main board from Ebay also BN41-02156A but from...
                        01-18-2024, 06:56 AM
                        09-06-2024, 11:40 PM
