Samsung C27A550U LED -No Backlight- Need Doku
+ More Options
Posts
  • Mr_K
    • 106
    Here i habe a faulty C27A550U. The Unit has no backlight. Everything else is working fine.
    The Main PCB is BN41-01652B with integrated LED driver. I can´t find any info or diagrams on the internet. Has anyone access to Samsung service files??? That would help a lot!!!
    (The only thing i found is The "A" Revision on ebay)
    Here is what i found so far:
    The fuse for the LED Driver was blown. And blows again if replaced. (it´s located on the left in front of the big black coil)
    When bridged, the display doesn´t start at all and the LED driver chip gets hot very quick.(located between the black coil and the flex connector) It is labled "bd9264efv" Can´t find any info on this one, too. Can you???
    So, if anyone can help me with this one it would be great! Datasheets will help me a lot, too!!!!
  • jetadm123
    • 2169
    Re: Samsung C27A550U LED -No Backlight- Need Doku
    I don't see any photo. Try posting your photo using "manage attachments".
    • Mr_K
      • 106
      *fixed* ....poor quality tough.....But thats the only one i found.
      • Mr_K
        • 106
        I have finally fixed the backlight. OK: I almost did.....
        There is a certain spot/area on the screen where is no backlight.
        Is this an indication for a faulty panel???I hope it´s not!
        I´m wondering if this might be caused by a bad flex cable from the main pcb to the panel. The contacts on one side are kind of "loose". They are "moving" on the foil.
        I´d like to know your opinion on this one before i take any further steps. The cable is f**** expensive.....
        • selldoor
          Slow Learner
          • 7870
          Can you tell us how you fixed it - that would be a great help for the fuure and
          maybe give us a clue as to why it is only partial?
          Have you any pictures of your set - inside or just these "Library ones)
          • Mr_K
            • 106
            Nothing special this time I just replaced the whole main board because there is absolutly no info about the LED driver chip nor was i able to get one for replacement.
            I have no HQ picture of the inside....
            Ok, could be a faulty replacement board but it was sold as tested and fully working. The question is: Is the backlight controlled "in one piece" (ON/OFF) or are there little segments with a seperate power supply and cable for each? It seems to me that these dark area is exactly one quarter of the screen. Maybe there are 4 seperate led segments and one has gone bad? Or the supply for one segment? Or just a bad cable so no power is coming through for one segment?
            • selldoor
              Slow Learner
              • 7870
              If you read this
              http://reviews.cnet.com/2795-6482_7-399.html
              It depends on what type of led tv it is. - Yours may be back lit with local dimming
              so one section may be out. I did find a pic by googling (Led tv panel then images )
              which shows the complex wiring arrangement.
                09-07-2024, 05:50 AM
              • C152Heavy
                by C152Heavy
                Summary for TL-DR readers:
                • VCC pin (18) of PFC...
                01-11-2023, 02:53 PM
              • howardc64
                Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                by howardc64
                Problem
                Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                Model & Board Pics
                Conflicting Spec
                Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                https://www.shopjimmy.com/vizio-gj-2k1...
                10-10-2024, 01:16 PM
              • Ierwin
                by Ierwin
                05-13-2025, 03:31 PM
              • Warrensmith
                Samsung BN44-00807E Low Backlight
                by Warrensmith
                Symptom is dim backlight - this set came in with almost no backlight.
                Samsung UN55JU6500FX2A
                1 - Replaced all backlight LED strips (set had lots of hours at level 20 backlight)
                2 - Changed out what appeared to be a bad Q9102C on BN44-00807E - not shorted or burned but appeared to be open. I was able to read (with difficulty) the part number - however I may have misread it - Can someone confirm that this is indeed an AOD9N40.
                Backlight improved significantly - about like it would be set to a level 3 or 4. Setting all the way to 20 seems to...
                10-27-2022, 07:09 AM
