Acer AL2016W banding
  • Undead
    • Mar 2012
    • 64
    Is there something specific to test when you get light/dark banding on a monitor? I am posting pics since this does not seem to be the same type of banding that I saw mentioned in other threads.
    My apologies for the quality of the pictures but it was really hard to get them to show up in the pics.
    (edit) I forgot to mention all the caps were already replaced with Panasonic FM series.
  • lcdman
    TinkerTech
    • Nov 2010
    • 232
    • U.S.A.
    Re: Acer AL2016W banding
    Hello Undead,
    Do you have another lcd panel (screen) that you could substitute for this one and see if it behaves the same way? If not could you post pictures of the rear of the lcd panel. Otherwise I would say that the lcd panel should be replaced.
    Good Luck on Your Monitor,
    lcdman
    • Undead
      • Mar 2012
      • 64
      Hi lcdman,
      I'll see what I can dig up, I have several X193w's around so will see if I can hook one of those up.
      • Rtech
        • Jul 2010
        • 1095
        I suspect the 193 W being a different resolution,will not give you a great image, but may be enough to give some some idea if the panel is the problem.I would take the cable off between the Screen and logic Board clean the top connector and refit, then see if that has helped with the original screen.
        • Undead
          • Mar 2012
          • 64
          Ok I tried the boards from the 193w and while it won't stay on, it keeps going into standby, when it is on for several seconds there does not appear to be any banding at all.
          I will give your suggestion a try now Rtech.
          • Undead
            • Mar 2012
            • 64
            Ok first of all I messed up. All my previous hookup did was turn on the lamps and did not actually use the monitor (no I wasn't thinking at all). I don't seem to have anything with a compatible connector. Cleaning the connector now.
            • Undead
              • Mar 2012
              • 64
              No change after cleaning the connector.
              What pictures would you like lcdman? Just the panel itself with the boards etc removed?
              • Rtech
                • Jul 2010
                • 1095
                I think the panel needs replacing !!
                • lcdman
                  TinkerTech
                  • Nov 2010
                  • 232
                  • U.S.A.
                  Hello Undead,
                  I wanted a picture of the back of your screen without the boards,steel cage,etc. And only to see the type of video connection. I had a similar Acer model that had two thin aluminium wrapped wire connections that went from the video/main board straight to the screen. Not the type of video connection used on alot of other lcd monitors that I've worked on before. I should have suggested to try cleaning and re-seating the connection. Kudos to Rtech as always.
                  Take Care,
                  lcdman
                  • Undead
                    • Mar 2012
                    • 64
                    Dull grey day so not the best light for pics, if they are not clear enough I will take better ones but I think they should show what you wanted to see.
                    Even if the screen is dead and needs to be replaced I would like to at least determine what exactly died on it. The important thing is learning
                    • lcdman
                      TinkerTech
                      • Nov 2010
                      • 232
                      • U.S.A.
                      Hello Undead,
                      I'm no expert on taking photos, but those look good to me. You have a common type connection for the video cable (LDVS). From what I've read on this site and personally learned about lcd screens, is that there is a thin plastic covered membrane with wires in it that connects to that long small circuit board. That membrane some times comes unbonded from the lcd element itself or sustains some damage (broken connection of the wire(s)). Thats what causes display issues like what your experiencing on this monitor. And thats not repairable. And thats why Rtech said to replace the screen.
                      Good Luck,
                      lcdman
                      • Undead
                        • Mar 2012
                        • 64
                        Well that would make sense. I can see where wires that small would not be repairable. Since it is dead I guess I can use it to take apart so I can see exactly what all makes up the complete screen.
                        Thank you very much for everyone who commented and shared your knowledge.
                        • Rtech
                          • Jul 2010
                          • 1095
                          If you are stripping it down,then suggest you keep the Backlights, as they may well be helpful in the future,either as replacements or to use as a test set, for future fault finding.
                          • Undead
                            • Mar 2012
                            • 64
                            Will definitely keep the backlights
                            Thanks for the tip.
                              09-06-2024, 05:27 AM
                              Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                              This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                              09-07-2024, 05:00 AM
                              Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                              This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                              Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                              This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              09-07-2024, 04:10 AM
                              Acer Aspire A317-53-37SZ + Pack Gold Acer 17'' Notebook 3 Specification for Upgrade or Repair
                              This specification for the Acer Aspire A317-53-37SZ + Pack Gold Acer 17'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A317-53-37SZ + Pack Gold Acer 17'' boardview and A317-53-37SZ + Pack Gold Acer 17'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                              09-07-2024, 03:10 AM
