Samsung 2494 SW powering off. Bad caps?
  • Tinker_Simpleton
    • Sep 2012
    We've had a couple of power outages recently and my monitor has been acting up. I've noticed a couple of things
    1) Changing windows from app to app triggers the monitor display functions to pop up in the lower right hand corner for a few seconds. Not every app and not all the time, but very annoying.
    2) For the second time today, my monitor has just shut off. Unplugging and replugging in the power cord to the power strip (Opti-USA surge/battery) allows the monitor to come back on.
    I had a previous Samsung that I replaced caps on, and can't recall exactly what the symptoms were, but I'm wondering if I should replace the caps on this one as well to fix my problem.
    I've searched the forums for my model of monitor and can't find it anywhere. If I do ned to replace caps, which ones should I get?
    Thanks for helping!
    John
  • Wrog
    • Oct 2009
    • 472
    Re: Samsung 2494 SW powering off. Bad caps?
    Could very well be bad caps. The replacements should be matched against what you currently have, so the next step should be to open up the monitor and make a list of what's in there (values, make, series and dimensions). Post the list, then folks can chime in on suitable replacements. Since you're in the US, typically people will recommend Panasonic FC/FM for power supplies. You could always check badcaps.net stock, though those are geared more towards motherboards and some values may not be available.
    • konecma
      • Sep 2013
      • 7
      • Czech
      Hello i need help.
      I have Samsung SyncMaster 2494HS
      What is this part? S301
        09-07-2024, 05:50 AM
      • black6host
        Replacement caps for Samson Resolv studio monitor 65A Amp board.
        by black6host
        Good day!
        I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
        I'm going to replace the caps and I'll be the first...
        02-06-2024, 08:22 PM
        by momaka
        03-15-2023, 10:17 PM
        by momaka
        03-12-2025, 03:42 PM
      • keepread
        Dell monitor PSU vs Dell laptop PSU
        by keepread
        Hi there!
        Someone gave me their old monitor, it's Dell S2715ht.
        The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
        Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
        10-30-2025, 04:45 PM
