Acer AL1916W Ab issue
  • emta41
    • Sep 2011
    • 8
    Ive read a lot of about possible issues with AL1916W, but I can still find out the right source of the issue.
    Monitor after power up flash up for 1 second, green LED flash up for one second and thats all.
    My AL1916W had:
    1) Bulged caps CE108, CE103, C204, all 220uF/25V on inverter board. Replaced.
    - still same issue
    2) The fuse F200 was blown out. Replaced.
    - The inverter board start work every second and shut down and again, again...
    3)Q206 AP40T03GP was blown. replaced with IRF540N. Its only for test, because IRF540 has Qg 47 nC and AP40T03GP has 8,8nC. It means that IRF540 will have bigger power loss(because the frequency) and the temp of IRF540N will be higher.
    - the issue and behavior is the same as it was at start of replacing. One flash of LCD and GREEN LED for one second and will come the dark after forever.
    Do you have any idea or hint, what else should be wrong or broken?
    I will be happy for any answer.
    Re: Acer AL1916W Ab issue
    I would replace the cap for the +5v power supply section also, bad cap can look normal.
    You may have bad transformer, bad lamp assemblies, ect.
    Please post good clear pictures of the board, bot sides.
    • sabre504
      • May 2010
      • 449
      Also check the voltage regulators on the video board ,
      had one do the same after recap turned out to be a 3.3v not working
      • Rtech
        • Jul 2010
        • 1095
        I have used the IRF 540 as a replacement for the last 2 years with no failures or returns.
        • Mirenia
          Acer Helios 500 (PH517-51) - unexpected reboots when laptop is warm (cold solder joint issue?)
          by Mirenia
          got an Acer Helios 500 Laptop (PH517-51) for diagnosing with a strange issue:
          The laptop runs for a while (1-2 hours, sometimes less) and then suddenly shuts completely off, like someone pulled the power cord and restarts immediately after on its own.
          If this happened once, then the laptop only runs for a few minutes until restart.
          This happens regardless while staying in windows or uefi or in a linux environment.
          At first I thought of a normal overheating issue, but as I monitored temps with HWInfo64, nothing seems very hot.
          01-05-2025, 05:15 PM
        • ahmarzo
          Acer laptop battery draining issue
          by ahmarzo
          Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
          Help me to diagnose this issue as there is no shortage in the inputs MOSFET
          08-02-2025, 06:39 AM
          09-06-2024, 05:27 AM
          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
          09-07-2024, 05:00 AM
          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
