VX2835WM shoppinglist
  • Lallekaj
    • Jul 2012
    • Denmark
    Hi
    I found this forum when searching for a replacement powersupply and it looks like there is some competent people sharing their knowledge here. Allow me to say thank you for that.
    I have this Viewsonic monitor and it's gone bad. No power but a ticking sound and occasional flicker in the indicatorlamp.
    I can see in the other threads conserning this issue, that the cure is a replacement of all capacitors.
    There is no pics, since it's recommended to replace them all.
    So I hope that somebody who did this before me have a list of the necessary caps to buy.
    Or? - Is there more to it?
  • selldoor
    Slow Learner
    • 7870
    Re: VX2835WM shoppinglist
    It may be as easy as that but sometimes when caps go they take out other components. Do you have a multimeter and soldering iron.
    I doubt if anyone will have a list and in any case it is better to prepare your own. The manufacturers change things on boards and yours may differ.
    When you open the set up look for bulged or burst caps. We would normally advise changing all of that make and series on the board first. The BIG cap only if it looks obviously flawed and the little ones last. Sometimes what you do depend on the availability of good name caps where you live. I can get almost any just 10 minutes away, no min order so can fix things buying one at a time.
    We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
    Examples of what is needed
    https://www.badcaps.net/forum/attach...1&d=1290283049
    https://www.badcaps.net/forum/attach...7&d=1280167246
    • hide08
      • 12
      The ticking sound might be a protection relay that is opening maybe due to a short circuit on one of the power rails.
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • the_rem
        Unknown transformer : how to find a good replacement part ?
        by the_rem
        Hello guys,
        I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
        I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
        04-23-2025, 01:48 AM
      • ezenia
        PS4 controller left stick potentiometer replacement issue
        by ezenia
        Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
        So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
        I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
        09-30-2023, 02:19 PM
      • boosti45
        Macbook pro logic board replacement parts quesion
        by boosti45
        i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
        08-21-2024, 05:23 AM
      • r2digital
        klipsch kda-500 amplifier suitable power supply capacitor replacement ?
        by r2digital
        I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
        04-18-2024, 03:50 PM
