Need help with Samsung syncmaster 910mp "function pcb"
  • mrfree
    • May 2012
    • 10
    • Italy
    I've a Samsung Syncmaster 910mp monitor but without what, on some schematic I've found on internet, they called it function pcb, where the front command switches are (like power, menu, enter and so on)
    I've only found schematics of the main pcb ho I can't find any details about the function pcb that I need to make from scratch... the only thing I've found is in the schematic of another Samsung tft monitor (171N) that uses the same chip where the inputs from the front commands end, the NT68F63L.
    However that other monitor uses a reference 5v instead on the 3.3v used in my 910mp, but if I've understand it correctly every switch simply closes the circuit with a different resistance value.
    If I still don't find anything I'll need to make some experiment searching for the right resistors values
    Does anyone have some useful details about that function pcb?
    Thanks in advance
  • selldoor
    Slow Learner
    • 7870
    Re: Need help with Samsung syncmaster 910mp "function pcb"
    Hi - what happened to the old switch board. Have you got any of it?
    Can you post pictures of what you have got and a picture of the front of the set where
    it goes showing the purpose of each switch.
    • mrfree
      • May 2012
      • 10
      • Italy
      I received that monitor as not working, I saved it from the trash and repaired it I suppose the previous owner has removed the speakers and the function pcb thinking the latter integrates the amplifier, but it's wrong... the ampli in on the main pcb in that model.
      So actually I haven't any little part of the original function pcb...
      Here is the image of the front panel commands:
      Googling I've found a partial image of what I need the function pcb is the little one on the image bottom.
      • selldoor
        Slow Learner
        • 7870
        Hi sorry to get your hopes up I thought I had one of these sets but mine is a 711mp which is a monitor/tv. I see yours has a scart socket which is kind of unusual for a monitor?
        Anyway I have taken it apart in case it is of some use in your project.
        Took ages to do the pics as I often tell people posting here that their pics are no good so I have to get mine fairly clear.
        • Scenic
          o.O
          • Sep 2007
          • 2642
          Any Samsung I've seen so far that had "MP" in the model number was a monitor/TV combo, sometimes with the TV tuner being optional (151MP/171MP)
          MP = Multi Purpose (Monitor + TV) !?
          @selldoor: The third pic in post #3 has the tuner box on the mainboard at the right, so it is actually a monitor/TV combo. Haven't seen those with SCART inputs yet though. Most of the MP's only had composite and S-Video.
          edit: I actually have a semi-dead 171MP, but I guess the "button" board (and it's resistors + IC) would be of no use as it has touch sensitive metal posts rather than normal buttons, so the entire PCB is probably completely different and incompatible.
          • mrfree
            • May 2012
            • 10
            • Italy
            Mine is a combo monitor/tv too... sorry I've been inaccurate describing it.
            The function pcb should hosts a ir-receiver too for the remote, but it's the last of my problem actually
            Let me take a better look at your pics... it's only a pcb with resitors, switches and a ir-receiver, isn't it?
            • selldoor
              Slow Learner
              • 7870
              Hi - yes resistors switches ir and a led (OL) - I will leave it in bits for a day or two in case you need to know anything else.
              @Scenic -Didnt spot that hahaha - wasnt looking too closely- I did wonder though
              and even googled the model number and it came up as monitor so as OP said monitor I just accepted it.
              • mrfree
                • May 2012
                • 10
                • Italy
                Ok many thanks selldoor, I'll try to draw the schematic from your photo on tomorrow...
                • mrfree
                  • May 2012
                  • 10
                  • Italy
                  Great pics! I can't only read the IR1 number
                  I drawed the schematic and found the 711mp schematics, it uses 3 different lines (KEY1, KEY2 and KEY3) for the nine buttons... the 910mp instead only has 2 key lines KEY_AD1 and KEY_AD2 I only made few tests but it doesn't seem to work
                  I think it could uses a different approach but I don't know which one
                  Any idea/suggestion is appreciate
                  • mrfree
                    • May 2012
                    • 10
                    • Italy
                    Thanks to your info and to my father's patience who has empirically discovered the resistors values I've finally build a working function PCB for my Samsung SyncMaster 910MP
                    Here is the schematic if someone is interested in it...
                    • selldoor
                      Slow Learner
                      • 7870
                      Well Done!- Pleased to hear you got it working and great that you post the
                      schematic for others.
                      • mrfree
                        • May 2012
                        • 10
                        • Italy
                        Better resolution... (I'd like to edit the previous post but it seems I can't edit my own posts)
                        • ariefkoes
                          • Dec 2012
                          • 3
                          • indonesia
                          I am having problems as above, but this is for samsung lcd monitor 743nx type. the original is a touch button in order:
                          power, auto adjust, enter, move up, move down menus.
                          I intend to replace the touch button to switch button for touch button can no longer be used because of a fluid leak lcd (now my lcd panel is replaced with a new one)
                          there are 4 pins that go into the old touch button: 3.3 v, key 1, key 2, led, gnd.
                          please help if you have a schematic diagram for my guide makes use swich button Function Panel
                          while I am trying to create a function panel following the schematic diagram for the type 910mp as above.
                          • ariefkoes
                            • Dec 2012
                            • 3
                            • indonesia
                            This is a sequence of buttons samsung 743nx, is using the touch button, I want to replace it with a switch button.
                            http://www.samsung.com/my/consumer/p.../LS17MYAKF/XME
                              09-07-2024, 05:50 AM
                              09-06-2024, 11:40 PM
                              09-06-2024, 08:40 PM
                              Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                              This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              09-06-2024, 06:20 PM
