acer al1916w going bad
+ More Options
Posts
  • motoxer
    • Apr 2012
    • 15
    • usa
    Monitor recently started repeating the logo screen and not showing the desktop. After 5 minutes or so of doing this, then it will turn on and work normally.
    A few days later, it would repeat the logo for a while and then the power light would go orange and fade in color and the monitor would go black. I could unplug and plug back in the power, then it would repeat the logo screen and work (eventually.)
    Keeps taking longer and longer to turn on, but once it's on it stays on...
    Is this bad caps, or something else? It's an acer al1916w from march 2008.
  • selldoor
    Slow Learner
    • 7870
    Re: acer al1916w going bad
    Hi - welcome to the forum. I dont know how much research you have done but
    if you type AL1916w into "Search" above, you may find an answer. If not you will see how to post pictures of the inside of your monitor and give you an idea of what is involved. Say if you have a multimeter and soldering tools and if you can use them and an indication of what electronic knowledge you have.
    • retiredcaps
      • Apr 2010
      • 9271
      Yes, it could be bad caps. As caps warm up their ESR drops and allows the circuit to work.
      --- begin sig file ---
      --- end sig file ---
      • motoxer
        • Apr 2012
        • 15
        • usa
        I looked some but most seemed to be monitors that didnt work at all, and got really confused with all of the comments saying it could use different power circuit boards etc.
        I'm still using the monitor and hoping for a quick fix before things go worse...
        thanks for the reply. i'm hoping it's just that and not something else
        I have a multimeter and soldering iron but neither are great quality. I'm hoping to just replace the normal caps and hope that it fixes it.
        I'm guessing it's better to open up the monitor first and look for damage before ordering?
        And, are ebay repair kits "bad" ?
        • retiredcaps
          • Apr 2010
          • 9271
          Yes.
          If you DIY using digikey with USPS 1st class shipping versus a "kit: you are likely to save 1/2 the cost.
          • sabre504
            • May 2010
            • 449
            • United Kingdom
            Thisa may be a bit early to mention but if your monitor uses this video board (see picture )
            The volt regulator at U7 (circled red ) can start to fail causing the same symptoms and when failed can cause no start up.
            Follow Retiredcaps and others advice and start with the PSU first though
            • 1supertech
              • Apr 2012
              • 384
              Hello wonderful people can solve my electronic problem I am a new to the electronic stuff. I purchased a AL1916w that will not start up I upon looking inside I noticed previous owner tried to fix it by replacing two capacitors 1000uf 25v with wrong heat range 85c. Soldering was very bad, after reordering with new caps I get blue light on start then goes yellow. 2 Fuses test good caps test with good esr’s I get 165 volts coming out of Big cap I get power to main board 12v & 5v
              I also plugged in my CCFL test bulbs no power to bulbs on start.
              I have the same mainboard as the picture above with two LDO regulators AMC1117 3.3
              The same regulator that is squared of in red in the pic above my voltage readings are
              Ground 0000
              Out 3.284
              In 0.476
              I am assuming this is bad ?
              The other regulator on the far right corner reads
              Ground 0000
              Out 3.283
              In 05.02
              • selldoor
                Slow Learner
                • 7870
                @1 supertech - we need pictures of YOUR boards its no good us looking at someone elses. If both LDO s are 3.3v then 3.284/3 reduction may be due to poor caps nearby is not far off - Your voltages 12v and 5v seem very exact - best to quote to 2 decimals
                Was it all connected up when you took voltages.
                • Rtech
                  • Jul 2010
                  • 1095
                  "I have the same mainboard as the picture above with two LDO regulators AMC1117 3.3
                  Ground 0000
                  Out 3.284
                  In 0.476
                  I am assuming this is bad ?"
                  Check the voltages again on this, I doubt if you can get 3.284 volts out,,with only 0.476volts going in !!!!!!!
                  • jetadm123
                    • 2169
                    Which 2 fuses did you check? Assuming you have a DAC-19M008 power board, a common failure for this board is one of the AOP605 dual mosfets shorting out and causuing fuse F200 to open. Check F200 first.
                    • 1supertech
                      • Apr 2012
                      • 384
                      It was all connected I will give you a more exact reading starting where
                      powerboard meets mainboard at top
                      2.711
                      000.1
                      000.1
                      05.02
                      12.01
                      05.02
                      0.540 but fluctuates
                      000.4
                      • 1supertech
                        • Apr 2012
                        • 384
                        No It's a dac 12M030
                        Round fuse behind power plug on power board and glass fuse near heatsink
                        I was wondering about the AOP605 how do you test them
                        • 1supertech
                          • Apr 2012
                          • 384
                          Ground 0000
                          Out 3.284
                          In 0.476
                          I tried it again and got the same reading
                          • jetadm123
                            • 2169
                            I believe for this power board, there's a surface mount fuse, F102, on the bottom of the board. Check to see if it's open.
                            Download the spec sheet for the AOP605. There are two mosfets in the AOP605. With your meter set to 200 ohms resistance:
                            For mosfet 1, measure across
                            D1-->G1
                            G1-->S1
                            D1-->S1
                            For mosfet 2, measure across
                            D2-->G2
                            G2-->S2
                            D2-->S2
                            A reading of approx 0-30 ohms will indicate a short. Perform this test for all 4 of the AOP605's.
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              Ground 0000
                              Out 3.284
                              In 0.476
                              What pins are you calling ground, in, and out?
                              • Rtech
                                • Jul 2010
                                • 1095
                                You can prove if the Power Supply/Inverter is working, as follows....Plug in you tests lamps,power up from the mains the power supply board ONLY,and apply 3v DC( from a couple of batteries maybe),beteween the BL ON pin and a Ground pin on the connector that would normally go to the Logic Board.This will indicate where you go next.
                                • 1supertech
                                  • Apr 2012
                                  • 384
                                  Ground frist pin on left
                                  Out is center pin
                                  In is frist on right
                                  • Rtech
                                    • Jul 2010
                                    • 1095
                                    Then there is someting wrong,Its not possible for a 3.3v LDO to give that voltage out with only approx 0.5 volts in...you have to have more in than you get out, and normally the input for the 3.3v regulator woul be approx 5 volts.However I suspect this is a 'red Herring', and should be put aside until you can get the PSU/Inverter working.Suggest you do the test as I suggested,and the resistance readings jetadm123 requested.
                                    • 1supertech
                                      • Apr 2012
                                      • 384
                                      I don't see BL on pin on power supply that connect to Logic board
                                      Tested all capacitors at 0.10 thru 0.25 on esr meter should I try replacing all anyway ?
                                      fuses
                                      f101 reads 000.0
                                      f200 reads 000.0
                                      suface mount fuse behind power plug is F101 don't see 102
                                      I tested Mosfet’s
                                      Top Mosfet 1
                                      D1-->G1 -08.76
                                      G1-->S1 -000.0
                                      D1-->S1 -08.81
                                      Mosfet 2
                                      D1-->G1-08.84
                                      G1-->S1- 000.0
                                      D1-->S1- 08.74
                                      Mosfet 3
                                      D1-->G1 08.68
                                      G1-->S1 000.0
                                      D1-->S1 08.28
                                      Mosfet 4
                                      D1-->G1 08.65
                                      G1-->S1 000.0
                                      D1-->S1 08.67
                                      • Rtech
                                        • Jul 2010
                                        • 1095
                                        The photo shows one line of pins,what about the other line,are they not marked ?? or is every pin in the top line connected to the pin immedoately below it...suggest some will be eg the Ground,it may be the DET pin,BUT check what the other ones are supposed to be..
                                          09-06-2024, 05:27 AM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:00 AM
                                          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 04:10 AM
                                          Acer Swift SF114-34-P2CV + Pack Gold Acer 14'' Notebook 1 Specification for Upgrade or Repair
                                          This specification for the Acer Swift SF114-34-P2CV + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P2CV + Pack Gold Acer 14'' boardview and SF114-34-P2CV + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-07-2024, 03:10 AM
