Dead, Daewoo 17" TFT-LCD Model HL710S
  • Ron K
    • Sep 2010
    • 17
    Dear Help
    I have a Daewoo 17" TFT-LCD Model HL710S monitor that is dead I cheacked all the Caps with an ESR tester and they all tested OK. When I put the neg to the big cap I get voltage ot both diods on the secondary section and also on I get voltage on the secondary caps. But their is no voltage at the 5 and 12 volt output pins. What component could be the problem
    Thanks, Ron
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Dead, Daewoo 17" TFT-LCD Model HL710S
    Originally posted by Ron K
    Dear Help
    1) Please specify the DC voltages that you are seeing at
    a) big cap
    b) secondary caps
    2) Post clear focused top down view pictures of all your boards following the instructions in my sig file below EXACTLY.
    --- begin sig file ---
    --- end sig file ---
    • Ron K
      • Sep 2010
      • 17
      I have the pictures put how do I attach them to this post? Where is your manage attachments button to attach the pictures? I tried (Go Advanced tab) then attach from there, but it doen't seem to work.
      Ron
      • jetadm123
        • 2169
        Ron
        When you reply to a post, you are given a box that allows you to type in text. If you scroll down, you will see another box titled "additional options". Within that box you will find "manage attachments".
        • selldoor
          Slow Learner
          • 7870
          Ron
          Hi if you are following instructions and they wont load they are probably too big
          - need to be less than 2mb
          • Ron K
            • Sep 2010
            • 17
            Dear help
            At the big cap I get 166 volts dc, IC chip grd to vcc 7.4 volts dc, secondary both diods I get 59 volts dc.
            Ron
            • Ron K
              • Sep 2010
              • 17
              Dear Help
              I have a Daewoo 17" TFT-LCD Model HL710S monitor that is dead I cheacked all the Caps with an ESR tester and they all tested OK. At the big cap I get 166 volts dc, IC chip grd to vcc 7.4 volts dc, secondary both diods I get 59 volts dc.
              Ron
              • selldoor
                Slow Learner
                • 7870
                Hi - your pictures are still not good enough - im not sure why - they need to be
                retaken so they are not blurred when enlarged. They should be around
                2mb jpgs.
                Did you do the output voltage test with all the boards connected. At very least
                the power supply and the main board need connected. I am trying to check
                if there are any fuses but its so difficult with the pictures being poor.
                Please also update your profile with country and voltage.
                • Ron K
                  • Sep 2010
                  • 17
                  Dear Help
                  Here are a new set of pictures with a better camera I hope they are clearer for you. Yes I tested the voltage with the the power supply and the main board connected, I also checked for a fuse but couldn't seem to find one. My Country is Canada and I am located in Manitoba.
                  Thanks for your time
                  • jetadm123
                    • 2169
                    What is the part number of the IC that you measured the 7.4V vcc?
                    • Ron K
                      • Sep 2010
                      • 17
                      The ICE part number is 2AS01, and another number is (a symbol then 0403LP).
                      • jetadm123
                        • 2169
                        It's a ICE2AS01 PWM controller. With power to your monitor disconnected, allow a minute for the main cap to discharge. With your meter set to 200 ohms, measure across pins 6 and 7 of the ICE2AS01. What is your reading?
                        • Ron K
                          • Sep 2010
                          • 17
                          With no power conected, big cap grained to 0 volts, on ICE2AS01 pin 7 grd to pin 6 vcc 0 volts. But with power conneced I get at the big cap I get 166 volts dc, ICE2AS01 pin 7 grd to Pin 6 vcc 7.4 volts dc, secondary sibe both diods I get 59 volts dc.
                          • jetadm123
                            • 2169
                            Let's try this again. I asked you to perform the pin 6 to pin 7 test on a resistance setting, not voltage setting. We're trying to determine if there's a short on the vcc pin.
                            • Ron K
                              • Sep 2010
                              • 17
                              meter set to 200 ohms on pin 6 to pin 7 their shows no or 0 resistance
                              • jetadm123
                                • 2169
                                If you're reading 0 ohms, then there is a short, which means one of two things:
                                1) There is an internal short of the ICE2SA01 between pins 6 and 7, which requires you replace the ICE2SA01.
                                2) There is a short to ground of one the components that is connected to the vcc pin 6 of the ICE2AS01. Your photos are not clear enough to read, but there should be a resistor, diode and cap(s) connected to pin 6. Check these for shorts.
                                  HP ZBook 14 G2 Base Model Notebook 14 Specification for Upgrade or Repair
                                  This specification for the HP ZBook 14 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 G2 Base Model boardview and 14 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                  09-06-2024, 05:27 AM
                                  HP EliteBook 840 G2 Base Model Notebook 800 Specification for Upgrade or Repair
                                  This specification for the HP EliteBook 840 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G2 Base Model boardview and 840 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  HP ProBook 640 G1 Base Model Notebook 600 Specification for Upgrade or Repair
                                  This specification for the HP ProBook 640 G1 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G1 Base Model boardview and 640 G1 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  HP ZBook 15u G2 Base Model Notebook 15 Specification for Upgrade or Repair
                                  This specification for the HP ZBook 15u G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15u G2 Base Model boardview and 15u G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                • ptcriserx3
                                  toshiba crt tv model mv20fm3 100% dead
                                  by ptcriserx3
                                  hi
                                  ive got an old 2002 toshiba crt tv
                                  its 100% dead
                                  no power on
                                  no standby light
                                  no click sounds
                                  nothing
                                  ps main fuse checks ok
                                  caps not bulged
                                  what would be most common failure to cause this?
                                  10-09-2023, 05:03 PM
