Sony GDM-20SE2T5 (Multiscan 20SE II) picture disappears
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    I've been given this monitor for free just before New Year's party, by one of the guests at the party. It behaves as follows: it starts up with no picture, then it shows up, then it goes away again and so on. It's like 2 minutes on 5 minutes off. The picture looks very good when it's on.
    I thought this was a problem with the tube heater but no, heater stays on. Same for all other voltages relevant to the CRT. After the picture has showed up once, when it disappears the display doesn't go fully blank, you can see faint outlines of the picture in dark grey. So i think the problem is on the signal board and not in the power supply or tube electronics.
    A service manual can be found here: http://www.eserviceinfo.com/download.php?fileid=27087 Any pointers are welcome.
    A working TV? How boring!
  • CyberPhoenix
    Issue with picture quality of Sony bravia TV
    by CyberPhoenix
    Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
    01-22-2024, 02:08 AM
  • noisykid
    Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
    by noisykid
    5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
    12-30-2024, 07:15 PM
  • tree5656
    diagnosing sony XBR-75X900H. NO PICTURE
    by tree5656
    This tv is not even 3 years old. its a sony XBR-75X900H, it was like a flashbang went off suddenly, tv faded to black and no picture. backlight is on. tried to do the power cycle, factory reset. i get beeps from remote if i tap up/down but no picture. how can i determine if its the panel or a board? i have replaced boards before im just not sure what the issue is here. sony said nothing they can do and only suggested to find a local repair shop. please guide me here
    11-09-2023, 04:55 PM
  • DKWS89
    Sony XBR 49x900E - Sound and backlight on but no picture
    by DKWS89
    Hey Guys,
    So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
    All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
    12-14-2023, 04:30 PM
  • ronni
    Sony KD-43XE8005 with sound, backlight, no picture
    by ronni
    I have a Sony KD-43XE8005 with no picture on the TV when powered on. Audio and backlight work ok when powering on. Solid white indication light showing on front of tv bezel.
    When removing the left hand ribbon cable from the T-con board, a white image is displayed on that half of the screen and a black screen is shown on the right. If I gently rub the ribbon cable on the right an image or purple black bars appear. The cable doesnt appear damaged, and if swapped with the other ribbon cable the same flickering symptoms can be seen.
    Removing the LVDS cable results in...
    12-01-2022, 08:44 AM
