Dell 2007FPb problems
  • zzmyers
    Grinch
    • Dec 2011
    • 3
    So, I had a Dell 2007FPb which would power off and back on every so often, randomly. Picture goes off, then immediately the Dell logo comes on the screen as the monitor goes through its power up sequence. Eventually, this monitor died and would not power on at all.
    Today, a second Dell 2007FPb started having the same problem. So, I pulled the totally dead one and after reading various different sources of data (including the board here), I opened it up and inspected the boards. 3 bulging caps on the power supply board -- so I replaced them. Also replaced 2 on the inverter board which looked slightly suspicious. Put it back together, fired it up and it worked! An hour later, it died again totally - would not power on again. Now I am scratching my head as I was sure it was those caps and I am not sure where to go from here on fixing this monitor (plus the 2nd one which is starting to die in the same way).
    Am I on the wrong track here? I didn't see anything else that looked bad inspecting the boards. Anyone else have a problem like this with a Dell monitor?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Dell 2007FPb problems
    1) What brand and series did you use for replacements? If you used general purpose caps from Radio Shack, they aren't the right caps for a SMPS application (which requires low ESR).
    2) Capacitors (C designation on the PCB board) die from age, heat, and shoddy build quality. Capacitors DO NOT have to be visibly bloated in order to bad. They can be out of tolerance uF (a 1000uF measures 20uF) and/or have high ESR (ohm). A multimeter will be insufficient to test for ESR. For that you need an ESR tester which costs between $50 and $300.
    3) Most members here will recommend that you replace ALL electrolytic capacitors with reputable brands from reputable sellers. Brands like Rubycon, Panasonic, and United Chemicon are suggested. A list of recommended caps can be found at
    https://www.badcaps.net/forum/showthread.php?t=2280
    The exception might be the largest filter cap since it rarely, but not never, fails.
    --- begin sig file ---
    --- end sig file ---
    • zzmyers
      Grinch
      • Dec 2011
      • 3
      That make sense as I did just pick up some caps from a local audio shop but they were nothing fancy. I'll go ahead and get some of the recommended caps and replace everything on the power supply. Especially as I have 2 failing the same way, the filter cap does not seem so likely so I will skip that one.
      Frustrating to have it almost fixed, but not quite. I'm going to pull it all apart again later today and spec out all my caps and go from there. Thanks.
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • DanPoka
        Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
        by DanPoka
        I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
        Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
        This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
        02-15-2025, 05:05 AM
        by momaka
        03-15-2023, 10:17 PM
      • Jesus Coder
        Issues Reviving Old Dell 2408WFPb Monitor
        by Jesus Coder
        I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
        06-25-2023, 02:33 PM
      • ChristianBr01
        Dell 34 inch U3419W Monitor with thin stripes on partial screen
        by ChristianBr01
        I have a Dell U3419W Monitor that has some thin stripes on a part of the screen since Tuesday.
        This lines cover about a third of the screen and appear for 2 seconds before disappear for another 2 seconds.
        This repeats the whole time. I have not opened the case yet cause I had no time, but will try to fix it on this weekend. For me, it looks like a problem on the TCon... Am I right?
        Does someone have seen this before?...
        05-23-2025, 06:06 AM
