Cornerstone 17" LCD monitor (white)
  • kb48
    • Nov 2011
    • 14
    Ran into a rather unique problem on this monitor.
    Powers on displays garbled lines all over screen, horizontal lines.
    Suspected may have been bad caps and so above the center processing IC
    I spot 4 caps, at least 1 looked suspect. Replaced all four and still same problem. (Replaced with slightly higher voltage rating as well).
    So I see the control chip is SMC8384-140 surface mount about 80 pin.
    Anyhow, I am then trying hair dryer method to see results.
    While feeding video, and heating this chip, first image grew with white lines, then lines started to disappear, and then woila perfect picture.
    But upon cooling down it regains it's lines again until unusable.
    I havent reflowed the cip just yet. Note that this unit had been in a garage and has been subjected to moisture, so I am hoping it is mold/mildew under the chip causing the problems.
    Unusual is that usually when you heat up a component it tends to want to fail more, or even just die. In this case it cures the problem instead.
    May also try spray out with component solvent to see.
    Its a nothing special monitor although it does have dual VGA inputs and a USB hub in there for whatever use.
    If reflow and cleaning don't work, looks likje it may need this chip, which I havent been able to source in quantity 1 from any distributors.
    The worthiness of it is at best questionable since it is not widescreen.
    It does seem to have a decent picture when you get past the thermal problem. Maybe I should just attach some lamps or heating element to the top of the chip? No that would be a bad idea.
    Maybe someone out there has one with a cracked screen or something I can get them to remove the mainboard. Has way too many screws of course.
  • DynaxSC
    ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
    by DynaxSC
    Hi
    I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
    08-04-2025, 12:20 PM
  • acedogblast
    by acedogblast
    11-02-2024, 05:13 PM
    by momaka
    03-15-2023, 10:17 PM
  • thstuff
    SONY BRAVIA XBR-55A8H - White horizontal lines / red LED flashes four times
    by thstuff
    This "free from a friend who was going to recycle it" SONY BRAVIA XBR-55A8H arrived with the bottom center RED LED repeating a four flash pattern. It was treated with kid gloves and was reported to have "just gone dead" and the OLED panel has no dents in the metal frame or cracks.
    Thread https://www.badcaps.net/forum/showthread.php?p=1091829 helped in proceeding as follows:
    1) Unplugged, then plugged set in while holding the remote VOL- and Power to factory reset.
    2) Waited 30 seconds, then pressed remote Power button and "Select language"...
    01-30-2023, 05:01 PM
    Common SPI bios chip programming Questions and Answers
    by SMDFlea
    Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
    A: If you can`t read from it how do you expect to write to it ?.
    Q: Why is my bios chip unreadable ?.
    A: The programmer is faulty or has a worn or broken zif socket.
    The USB cable is frayed,connector pins worn or some other physical damage.
    Not enough amperage or voltage to power the programmer properly.
    Bad...
    09-02-2021, 04:40 PM
