"x2gen" 22" with intermittant flicker fix
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    one of these came in for recycling a while back.the shop helper kid wanted it so we looked into fixing it.had a dead external brick psu.you guessed it.bad caps.fixed that and it worked.recently he reported an occasional flicker.got inside and found a 220@16 near the +3.3 reg open.the others were 100@16 and were marginal esr.
    replaced them and flicker gone.
  • fixit007
    Samsung flicker - BN44-00932T board or else?
    by fixit007
    I picked up this TV that the prior owner said - just died.
    Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
    Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
    Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
    05-04-2024, 06:14 PM
  • howardc64
    UN65TU7000 strobing / flicker
    by howardc64
    Good picture but has ~200Hz+ faint flicker/strobing over entire screen. Also has a single green vertical line. Can mask out t-con signals (2pins) to stop flicker/strobing but 1/12 of screen will be all colorful vertical lines (single green vertical line is in this section)
    Since can mask t-con signal to disable part of the screen and stop flicker/strobing. Obviously not backlight.
    Panel has 4x driver boards each responsible for 1/4 of the screen. 3 tabs on each board. Each tab responsible for 1/12 of the screen. the 2 outer most tabs has additional horizontal gate control...
    03-26-2023, 04:37 PM
  • liquidzorch
    ideapad 15imh05 Intermittant no audio device
    by liquidzorch
    I have an ideapad gaming 3 15imh05 here that has an intermittant issue with audio. The device will dissapear from device manager randomly. Most of the time it does not work. I have tested the continuity of the SDATA_IN, HDA_SDOUT_AUDIO, HDA_BITCLK_AUDIO, and HDA_SYNC_AUDIO, all to the pch (or the resistors near it), and all lines are good. They have no voltage though ( I have not been able to test when it's working). HDA_RST# from the pch only goes to a capactor to ground and that's it, so it's not used. What other lines should I check? What lines ares used to detect the device?
    Thanks in...
    08-13-2025, 09:30 PM
  • sgcampion
    Asus rog strix scar 17 G733QR display Issue(flicker, black/white))
    by sgcampion
    My Asus laptop started flickering from time to time and more and more in last months. First the screen was going black but sometimes if I moved the screen it would work again, other times I needed to plug/unplug the laptop or close and open the lid to make it work again.
    In last days I see that if I move the laptop lid to about 45 degrees it will flicker or get white or black screen(it's random, sometimes white sometimes flickers etc). I was trying to troubleshoot it myself but seems like it's either the cable or the display....
    10-24-2023, 09:39 AM
  • russianbar
    SONY KD-65XE7002 Screen Flicker
    by russianbar
    This isn't my video but it's a fair representation of the fault I have, starts with slight screen flicker as the set warms up which happens every 5 seconds or so that gets more regular until more or less constant https://www.youtube.com/watch?v=Un8cAjUtOvA was thinking T-Con but open to any other ideas as seems to be quite a common fault on these
    04-10-2025, 03:11 PM
