DCLCD DCL20 (Scepter) 20" LCD won't turn on
  • Rezolution
    • Oct 2011
    A coworker was going to throw his monitor out but I said I would take it to see if I could fix it. He said that he was moving it from one room to another and then when he put it on his desk, the A/C cord wasn't plugged in it all the way when he turned the monitor on. Once he hit the power button, he heard a pop, saw a white flash come from inside the monitor, and then the monitor wouldn't turn on any more.
    I took the whole monitor apart thinking I would see a popped cap or diode, but I see nothing that's popped, bulged, or burnt at all on the main power board.
    Anyone have any idea what I should be checking for? I didn't see anything that looked like a fuse, but a fuse can look like anything now-a-days.
    The monitor does nothing when it's plugged in and nothing when you press the power button, no blinking lights, nothing at all. I only inspected the power board, not the video board though.
    I can take pics of the power board if someone could tell me where to start looking. I have limited knowledge of newer electronic parts but I'm very good at soldering and using a DMM.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: DCLCD DCL20 (Scepter) 20" LCD won't turn on
    For best picture quality and clarity take your boards to a window on a sunny day, turn flash off, and use macro mode. Take a top down view of all your boards (front and back). Make sure the photo is legible so that we can read the PCB printing clearly. A shutter speed of 1/125 or faster will produce nice clear focused pictures. Try to get a photo that is 2000x2000 resolution or as close as possible.
    Here is an example of the pictures we want.
    https://www.badcaps.net/forum/showpo...94&postcount=1
    Also see my sig on how to attach the pictures.
    --- begin sig file ---
    --- end sig file ---
    • retiredcaps
      • Apr 2010
      • 9271
      Fuses are marked with a "F" on the pcb board. An example, would be F100. A good fuse should measure less than 1.0 ohms. When measuring resistance, always turn off the power and have the device unplugged.
      The next likely candidate to test is the bridge rectifier (marked BD). It has 4 pins. Measure the resistance between pins 1-2, 1-3, 1-4, 2-3, 2-4, and 3-4. Any reading under 30 ohms suggest a possible short (bad).
      Both measurements above can be done "in circuit".
      • mockingbird
        • Dec 2008
        • 5484
        Sorry to bring up an old thread. I felt this lesson had to be shared.
        I had this monitor sitting around for ages waiting for the opportune time to get re-capped. I finally got some 20mm 16V 1500uF caps (Originals are 25V 1000uF). I re-capped the thing, and voila! it works.
        Problem is, the panel is cracked. Next time, I better pay close attention. It was discarded because of the panel, not because it didn't work.
        If anyone needs some parts of this thing, let me know.
        • wattage
          AOC AG493UCX 49-inch monitor - Firmware request
          by wattage
          Hello Badcaps Community,
          The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
          07-13-2025, 04:41 PM
        • ant3202
          HP 27es - LED monitor - Monitor Flashing On - Off
          by ant3202
          Hi Everyone
          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
          https://www.badcaps.net/forum/troubl...lashing-on-off
          The monitor is HP 27es LED Monitor
          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
          The monitor will randomly blackout and display no signal and will recover again.
          Sometimes need to power and off again to restore the display but...
          03-20-2025, 07:30 PM
        • pajdek
          Lenovo Y700-17ISK turn on and off
          by pajdek
          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
          09-20-2023, 02:49 AM
        • sew333
          Pc shutdown, monitor flickered with no signal after 10 seconds
          by sew333
          My pc:
          10850K stock 4800mhz stock Kraken X73 good temps
          2x16 GB DDR4 GSKILL 3000mhz XMP
          Seasonic Tx-850 Ultra Titanium
          Gigabyte Rtx 3090 Gaming OC
          Aorus Z490 Pro Gaming
          1 TB SSD
          4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
          Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
          Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
          Power...
          02-22-2022, 10:27 AM
        • matthewmcconaughey
          I need help with my friend Sony GDM-FW900 24” CRT
          by matthewmcconaughey
          Hello, Badcaps is my last resort. I am the first owner of the monitor. I reached almost every repair store in my area, but no one even wanted to hear about troubleshooting an old CRT monitor. At this point, I have been trying to figure it out by myself, but I have no idea where to start or look for.
          I wish to know how to think and locate a failing component. I will put all my efforts to learn and contribute.
          1. It started with a bright and greenish picture upon starting a cold monitor.
          2. About 2 years ago, only on the cold boot, the screen started to occasionally flash with
          05-16-2023, 03:15 PM
