Acer AL2032W repair. I'm Stumped!
  • keg35
    • Aug 2011
    I have an Acer AL2032w LCD monitor that is about 4-5 yrs old.
    When I turn my computer off at night and restart it in the morning my monitor will not turn on at all. (The orange light is on then goes out and there is no other light). I did some research and thought that it was the TFT INVERTER BOARD (http://www.ebay.com.au/itm/55-L38VE-...item2563f578b5) so I brought this off ebay and replaced it.
    The monitor is still doing the same thing.
    I then turned off just the monitor (using the off/on button) and it turns back on straight away. I turned the monitor off at night then in the morning it would not turn on again.
    To get it going again I have to undo the back panel and when I do this and plug it in it powers on...It's got me stumped as to what it may be.
    Any ideas appreciated..Thanks
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Acer AL2032W repair. I'm Stumped!
    This sounds like bad caps on the power board. As the monitor warms up, the cap's ESR (ohms) is lowered. When cold, the ESR is high and the monitor won't come on.
    Take a top down view of all your boards (front and back). Make sure the photo is legible so that we can read the PCB printing clearly. A shutter speed of 1/125 or faster will produce nice clear focused pictures. Try to get a photo that is 2000x2000 resolution or as close as possible.
    Here is an example of the pictures we want and see my sig file below on how to upload the pictures.
    https://www.badcaps.net/forum/showpo...94&postcount=1
    --- begin sig file ---
    --- end sig file ---
    • keg35
      • Aug 2011
      Thanks for the reply "retiredcaps".
      Is this the power board?
      If so it's new and the problem is still there.
      Cheers
      • retiredcaps
        • Apr 2010
        • 9271
        The power board is where your AC cord plugs into.
        • testmachine
          • Dec 2012
          • 5
          this is an older thread has any one found an answer. i have the same monitor but the power light blinks amber. and it wont turn on fully any more. it did work about a month ago, but it has slowly stopped working. i have taken it apart and the caps "seem" ok to me. i have read 4 other threads on this monitor but haven't found a solid answer. should i create a new thread to start from the beginning of trouble shooting process?
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            Well, it depends on the problem
            This seems a pretty solid answer
            https://www.badcaps.net/forum/showpo...7&postcount=29
            Welcome to the forum-
            We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
            Examples of what is needed
            https://www.badcaps.net/forum/attach...7&d=1280167246
            https://www.badcaps.net/forum/attach...6&d=1280167246
            https://www.badcaps.net/forum/attach...4&d=1280167246
            It will be useful if you can say what the supposed fault was and a bit about yourself - skills tools etc.
            • testmachine
              • Dec 2012
              • 5
              Dang, I didn't see that one at all when I searched. I just found the 5 16v 330uf caps of which he speaks. Now I just need to find some one to replace them for me. I don't have enough skill in soldering to do this. the extent of my skill is soldering a switch, batteries and a red laser inside a nerf gun. any other words of wisdom before i start calling around my area?
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                They may not be the whole problem - if you had replaced them weeks ago when it was
                starting to fault would have been better - as they get worse they put pressure on other
                components. We would normally recommend replacing all the caps except the large one
                unless the others are a decent make.
                For replacements try to get panasonic FM or FR - careful to check the physical size.
                Radioshack or frys ones are unlikely to last long.
                Merry Christmas
                • testmachine
                  • Dec 2012
                  • 5
                  Doesn't badcaps.net replace caps for a charge? Who can I email/call to get things rolling. thanks so much for your help. Merry Christmas to you as well.
                  • Mr Bill
                    • Nov 2011
                    • 648
                    This link should go straight to Topcat.
                    https://www.badcaps.net/pages.php?vid=99
                    • testmachine
                      • Dec 2012
                      • 5
                      Just a little follow up. I did what this person in this link did
                      solid answer!!!
                      https://www.badcaps.net/forum/showpos...7&postcount=29
                      well I didn't do it, I payed someone in an electronics supply store 50 bucks for parts and labor and my monitor is back in business!
                      • selldoor
                        Slow Learner
                        • Dec 2010
                        • 7870
                        What did you do? get *iss*d?
                        • Borisward
                          • Mar 2013
                          Seems like heating problem. If you Ac is not working get it repaired and for now you have to call a technician
                          _________________________
                          Tri-county AC Repair Davie FL
                            by momaka
                            03-15-2023, 10:17 PM
                          • maralexbar
                            How to force Acer Aspire Series to bootup BIOS/UEFI on external Monitor?
                            by maralexbar
                            I ask this question in general as there are many Acer Aspire models with UEFI Insyde BIOS that do not boot to the BIOS on an external monitor (VGA, HDMI, etc) showing only the Internal LCD (LVDS, eDP etc).
                            It's a pain to work on Acer notebooks with a broken screen and not being able to access the BIOS using an external monitor.
                            If anyone knows how to force the external monitor as primary for Notebooks of those models
                            11-02-2024, 09:18 AM
                            09-06-2024, 05:27 AM
                            Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                            This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                            09-07-2024, 05:00 AM
                            Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                            This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
