Sun 24.1 LCD / Samsung 244T (LTM240M2-L03) will not power on after badcaps replaced
  • whiteboy
    • Oct 2011
    • 19
    Hello all!
    My name is ken and I have followed several threads https://www.badcaps.net/forum/showth...light=sun+24.1 and http://s807.photobucket.com/albums/y...AMSUNG%20244T/ concerning the LTM240M2 displays and problems surrounding the AC inverters. I have two identical Sun LCD's which are affected by the same problem. After examining the AC inverter board, I was able to visually confirm 3 bad 1000uf 35v capacitors. So I got a few of those from radioshack, unsoldered the bad ones, installed the new ones, reassembled the monitor, and now it doesn't even reach standby. My other display remains untouched, however it is not reaching standby power either. Neither display turns on, nor do they flash the LED to indicate status. I paid very close attention to how the displays were constructed as I disassembled and reassembled each one. As far as I can see, everything is as it was before disassembly.
    I will include several before/after shots of the AC inverter board as well as the other logic board. Please help me badcaps! I dont know what I've done wrong here since my other monitor should at least have a blinking green LED (which was the initial problem).
    PS: I noticed on the other logic board there is an AC 1501-33 IC buck booster chip. I have a multimeter but I am unsure how to probe my boards to see if they are recieving the needed voltage[s]. Thank you.
    Pictures located at http://imgur.com/a/1gTLl as well.
    Many thanks in advance!
    -Ken
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Sun 24.1 LCD / Samsung 244T (LTM240M2-L03) will not power on after badcaps replac
    Radio Shack doesn't sell low ESR capacitors which are required in a SMPS application.
    In addition, Capxon are really bad capacitors (only Fuhjyuu is worse) so anything that says Capxon should also be replaced. The only exception would be the largest cap on the board. It rarely, but not never, fails.
    Suitable replacements can be ordered from digikey.com. Members prefer Panasonic FR, FM, and FC (in that order).
    So replace ALL your electrolytic capacitors on the power/inverter board and then check for 5V SB.
    Capacitors die from age, heat, and shoddy build quality. Capacitors DO NOT have to be visibly bloated in order to bad. They can be out of tolerance uF (a 1000uF measures 20uF) and/or have high ESR (ohm). A multimeter will be insufficient to test for ESR. For that you need an ESR tester which costs between $50 and $300
    --- begin sig file ---
    --- end sig file ---
    • whiteboy
      • Oct 2011
      • 19
      two questions: How do I meter my monitor? How do I determine why the 2nd display (Capxon caps remain within) wont reach standby?
      • whiteboy
        • Oct 2011
        • 19
        Also what IC's am I supposed to be metering?
        • retiredcaps
          • Apr 2010
          • 9271
          In the other thread, there is a top down picture of the power board in post #1. This is our preferred view, not the angle look you have.
          On the left hand side of the power board as per picture in post #1, there is a 4 pin connector. It says 5.3V, GND, 5V SB, and something else I cannot make out.
          Make sure the monitor is plugged in.
          Put your black lead into COM, red lead into voltage. Put your multimeter to 20V DC if manual ranging. Put your black probe on the GND and your red probe on 5V SB.
          Report this reading.
          • retiredcaps
            • Apr 2010
            • 9271
            Also note that budm shows the replacement caps and they are Panasonic (you can tell from the "T" vent on top). So again, your Radio Shack caps are only "general purpose" caps and not "low ESR" caps.
            Low ESR caps are required in a SMPS application.
            • whiteboy
              • Oct 2011
              • 19
              Retirecaps, I believe my ac inverter board is different than the one listed @ https://www.badcaps.net/forum/showth...light=sun+24.1. Before I buy anything else I need to test my other display with the Capxcom caps to verify if its receiving power or not.
              • retiredcaps
                • Apr 2010
                • 9271
                Please post a picture (right side up) of the red/black connectors so we can see the legend and pin numbering.
                Also, in this top down picture, you have another bloated cap. It is just left and slightly above of the "solder direction" on the pcb.
                Don't order anything yet until we measure some voltages.
                • whiteboy
                  • Oct 2011
                  • 19
                  Wow retirecaps, what an eye! I have 20/20 here and didn't see that ;-) Here are the requested pictures, I hope they are posted correctly:
                  The red black cables are labeled 1 & 1 - 14
                  Also tell me how I can test my caps (if possible) with my IDEAL 61-340 meter.
                  Best,
                  Ken
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    I wish I had 20/20 vision. Unfortunately, after many years of computer use, they have degraded.
                    Right next to pin 14 is a ground screw. Put your board back inside the monitor and put the screw in.
                    Dial your multimeter to read DC volts.
                    Put your black probe on the ground screw by pin 14. Put your red probe on every pin on each connector. We are looking for 5.4V, 6.2V, 13V, and/or 24V (as per legend). Some will be 0V (for ground).
                    List each connector, pin, and DC V reading in some readable tabular format.
                    Your multimeter can read caps up to 4000uF according to the manual. Caps have to read "out of circuit". That is, desoldered.
                    Dial your multimeter to read capacitance.
                    Put your red probe on the positive and black on the negative leg of the cap. A good cap should read close to the value stated on the sleeve. A bloated cap will read significantly less. I can already tell you that once you desoldered that small bloated cap, it will read less than the sleeve uF.
                    Remember a multimeter does not measure ESR.
                    • whiteboy
                      • Oct 2011
                      • 19
                      RetiredCaps,
                      I measured both monitors and here are the results
                      Monitor A (Unchanged)
                      1: 1.4v to .810v to 1.6v
                      2: 0
                      3: 0
                      1: 0
                      2: 0
                      3: 0
                      4: 0
                      5: 0
                      6: 0
                      7: 0
                      8: 0
                      9: 0
                      10: 000.1mV
                      11: 0
                      12: 0
                      13: 0
                      14: 0
                      Monitor B (4 Caps swapped)
                      1: 1.811V to 2.1V to 2.24V
                      2: 0
                      3: 0
                      1: 0
                      2: 0
                      3: 0
                      4: 0
                      5: 0
                      6: 0
                      7: 0
                      8: 0
                      9: 0
                      10: 000.1mV
                      11: 000.1mV
                      12: 0
                      13: 0
                      14: 0
                      It seems that the first pin is constantly climbing on both monitors. Each system was metered with the front bezel removed and the front panel switches unplugged. Is there anything else I should be meter?
                      Best,
                      Ken
                      • whiteboy
                        • Oct 2011
                        • 19
                        btw you were correct regarding the capacitor values being altered....each 1000uF cap measured at least 1/2 of its capacitance!
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          1) Let's stick with the original monitor for troubleshooting. Doing this remotely is difficult enough, adding another monitor, though identical, doubles the complexity.
                          2) All the secondary 0.00 V DC indicate that the SMPS is not starting.
                          3) I'm not sure which little cap is the startup cap, but measure the DC voltage across each cap circled in red. Red probe to + and black probe to -. Report if the voltage is steady of fluctuating. We know one of the little caps is bad for sure and will definitely need to be replaced. This one cap could be the startup and sole reason why the SMPS doesn't start.
                          Report all readings and their board location/designation.
                          4) CAREFULLY, measure the DC voltage across the largest cap. Red probe to + and black probe to -. This reading could range anywhere from 165DC to 375V DC when working.
                          • m1ch43lzm
                            by m1ch43lzm
                            05-12-2025, 08:37 PM
                          • ohren
                            by ohren
                            09-08-2023, 05:24 PM
                          • ermals
                            Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
                            by ermals
                            Hi all!
                            I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
                            1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
                            2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
                            3. I've checked voltages...
                            08-01-2022, 10:35 AM
                            09-07-2024, 05:50 AM
                          • valvashon
                            Samsung UN65KU6290F PS board blows fuses
                            by valvashon
                            Samsung UN65KU6290F (May 2017); received from local Buy Nothing group. Was listed as "just went dead" and they wanted it gone. I brought it home, didn't notice anything visually wrong with the power supply board, looked up the cost of a new one and that's about as far as it went. Family was tired of tripping on the foot of the set so I decided to dig in and repair or toss.
                            Can't believe that I didn't check it earlier but I found the main 8 amp fuse blown. Jumped across it with a 10 amp blade style fuse and you can see that it literally exploded inside the second I plugged...
                            11-27-2023, 01:09 PM
