Yes, flux makes SMT work a breeze.
Wow. Are you sure those are the voltages you got? If so, we have a problem.
FB1, FB2, and FBP should be close to 1.25V. FBN should be close to 125mV.
Try measuring those voltages again and see if VDD+9V is still 9v. Let me know if it's not
I also dug in a little deeper into the Max1997 data sheet, and found some more useful info - mainly, there's 2 other voltage rails besides VGH and VGL. One of them is very important and gives power to the main controller on the t-con, IC1. The voltages you got above for FB1, FB2, FBN, and FBP indicate that one (or more) of these rails has a problem and is likely pulling all of the other rails down with it.
So first thing you need to do is determine which rail is where on your t-con board so we can check and troubleshoot each one.
To do that, first locate pin 3 (DRV1) on the MAX1997 IC. Now, with your multimeter set to continuity check, you should find that one of the pins on one of the transistors is connected to pin 3 (DRV1). You'll know this when the multimeter beeps and shows a very low number (less than 2 on the screen).
Note that there are 5 transistors on your t-con: Q502 (the big one with 4 pins), Q501 (all the way to the left side, next to C523 and C524), Q504 (midway between Q502 and Q501), Q503 (below the MAX1997 IC), and Q505 (next to lower-left corner of inductor "4R7"). I'm using this picture as a reference:
https://www.badcaps.net/forum/attach...4&d=1318106711
Once you find which pin of which transistor is connected to pin 3 (DRV1), post the information here. Then repeat the same procedure above for pin 9 (DRVN), pin 19 (DRV2), and pin 22 (DRVP) of the MAX1997 IC - i.e. find the transistors to which these pins are connected to.
Next, do a similar procedure as above for VGH, VGL, and VGC - that is, connect one probe of your multimeter to VGH/VGL/VGC, and find which transistor it connects to.
All of this will give us a complete description of where each rail is located on the t-con. Once we know this, then we can test each rail's components thoroughly to see where the fault is.
This shouldn't be that much work - of course, if you think it is, then let me know. I hope I'm not giving you a headache with this stuff
I think I'll try replacing C501 since the rest seems normal?
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
