The next common failuer [food for thought]
  • alexanna
    • Mar 2010
    • 1346
    I am going to make a prediction, have seen some evidence that we will see this more of this.
    I think it's time for people to get comfortable going into the LCD panels and at the minimum repairing poor soldering on the CCFLs.The good thing is testing will be straight forward and easy.
    Granted replacing bulging capacitors is easier, but repairing a poor connection on a CCFl if that is indeed the problem is going to be easier than dealing with the protection circuitry of the inverter. It's next to impossible to find a schematic, and what are we going to if the manufacture starts using more of what I think it's been called “in house numbers” on their ICs?
    It gets very pricy replacing CCFLs,But in my opinion There is nothing wrong in using a good used CCFl from another monitor that for one reason or another we have decided not to repair.
    Something's I have noticed with wiring on CCFLs are:
    What we call 2 sec to black, this time period could go up to 5 minutes or more.
    Flickering of the LCD panel particularly when everything is good and warm.
    And in severe cases sizzling coming from inside the panel or the inverter coil
    • Jul 2011
    • 6031
    Re: The next common failuer [food for thought]
    I would second this idea
    • PlainBill
      • Feb 2009
      • 7034
      The economics has shifted to the point that purchasing a set of new CCFLs to repair a 19" monitor is uneconomical. With 20" wide screen monitors selling for under $100, even replacing caps is barely worth it. Still, on the larger size monitors it's worth it.
      There are two problems with going into the LCD panel. It requires significantly better mechanical skills, and cleanliness is very important. I've got one in front of me right now that I didn't do very well on.
      PlainBill
      • Rtech
        • Jul 2010
        • 1095
        I have found over many months that the fault associated with CCFLs,is more likely to be a wiring fault as opposed to a lamp fault itself.The wiring fault always seems to be on the return wire end of the lamp,and is usually a burnt out wire or bad joint.I considered either bad soldering in manufacturing,poor quality solder, or poor quality return wire,and dismissed a burn out due to excess current as the CCFL current is usually no more than 8-10 ma dependant on lamp length.On a number of lamps,where the return wire is burnt out I have recently replaced both return wires with 30AWG Kynar wire,3Amp current rating, heat reisistant in excess of 105degrees,and very easy to work with as this was mainly used in wirewrap applications,and therefore it is easy to put a number of turns on the lamp contact,making a very good mechanical joint,and then solder as normal.A lot of 'soak' testing outside a screen seemed to be fine,so the next test would then be to run them in situ in a Monitor,and see what happens.My son has been running one for a number of months with no problem,as has my daughter,so I have decided to continue using this system.
        • retiredcaps
          • Apr 2010
          • 9271
          Of course, I get a nice Acer 19 inch 2008 circa wide screen monitor that according to the previous owner won't stay powered on. I was hoping for bad caps and an easy fix.
          However, I could hear arcing and feel the top corner of the monitor get warm. Finally, I decided it is time and take one of these lcd things completely apart since this monitor was made in 2008. Sure enough, I can see the burnt crispy return wiring. Sigh.
          The bulbs are good (no signs of damage). Now to figure out how to do this without wrecking anything.
          Time to look at the ccflwarehouse and ccfldirect tutorials in greater detail.
          --- begin sig file ---
          --- end sig file ---
          • J_T
            Operating frequency for motherboard common mode inductor/filter
            by J_T
            I have a question - I have replaced the PSU on my own iMac Pro. However, when removing the motherboard I knocked of a 120 OHM 30% 0.3A small surface mount common mode inductor/filter (~0602 size) in the ethernet circuit near the female RJ45 port.
            The closest match I can find on Mouser is 120 OHM common mode inductor at 100MHz - my question is this frequency correct for a motherboard? The schematic for the motherboard only provides '120 OHM 30% 0.3A' and the TDK part number does not return anything in google.
            Sorry, I am not experienced hence a basic question.
            01-04-2025, 05:54 AM
          • Jane
            HP ProBook 450-G2 LA-B181P - What is a common resistance?
            by Jane
            I have faulty HP ProBook 450-G2 LA-B181P - doesnot start. When connecting a charger, the LED on plug in connector blinks from yellow to blue. (I tried to search a short on mainboard.)
            What is a common resistance ( to ground ) I should measure on a coil that leads to VGA chip(RT8880CGQW) ? I measure only about 9.6 Ohms. Is it normal?
            03-11-2025, 05:26 AM
          • Techie_hobby1
            Help with a poorly looking component identification plea
            by Techie_hobby1
            A friend of the family has handed me a food warmer that has failed on her.
            I appreciate that some people will alert me that it is probably cheaply made, but she has extremely limited mobility, and it is perfect for keeping her food nice and warm, once her carers have left.
            It has 2 power options (either 12V DC cigarette lighter or AC 240v IEC C7 socket).
            Basically, it powers 2 x PTC elements which are attached to a metal plate.
            A (removable)metal deep tray is then placed on-top of the small plate which keeps the food nice and warm.
            I thought at first...
            03-23-2025, 06:54 PM
          • ctroxtell
            Carrier HK50AA063 display controller common failure help
            by ctroxtell
            I've got a control display for a Carrier chiller that I'm trying to understand what the common failure with these boards are. This is the board in question https://www.supplyhouse.com/Carrier-...arquee-Display all of them seem to develop a failure with the up and down arrow buttons on the right side of the display, the esc and enter keys I've never seen fail. Once these boards are plugged in they run 24/7, you used to have to press extremely hard with the end of the blunt screwdriver and you could still get the arrows to work but now it has completely stopped working. The button...
            02-05-2025, 05:31 PM
          • reformatt
            Intel iMacs, 3rd party SSD failures and Fusion setups
            by reformatt
            I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
            As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
            So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
            12-18-2024, 10:34 PM
