Dell E198FPb 19" LCD Monitor
+ More Options
Posts
  • soulripper
    • Aug 2011
    • 22
    When Connected to a Pc is works but it Flickers to different Color Tints,Green,Blue,Red constantly. Could anybody tell what might be wrong with it or what to check for.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Dell E198FPb 19" LCD Monitor
    Open it up, check for bad capacitors on the power supply / inverter. Check for bad brands of caps (check the FAQ for a list of 'replace on sight' caps) on the signal card and replace any that are suspect. Check the voltages out of the LDO regulators on the signal card.
    If you need further instructions, take pictures of the top and bottom of the poser supply / inverter and of the top of the signal card. Well lit, sharply focused pictures of at least 1000 x 1000 pixels are desired. Attach them using 'Manage Attachments' - below the text entry area. Do NOT post them inline.
    PlainBill
    • soulripper
      • Aug 2011
      • 22
      Ok, will do thanks.
      • soulripper
        • Aug 2011
        • 22
        I have open the Monitor and quite a bit is looking bad so decided not to persue this repair. not really looking to spend so much Money on parts.thanks for you're interest but it seems is not worth my time.
        • PlainBill
          • Feb 2009
          • 7034
          Ahh, how much money do you think it will cost? If you do a complete recap, you are looking at about $10 for caps and shipping.
          PlainBill
          • soulripper
            • Aug 2011
            • 22
            Is more than Caps other things look bad I mean over all it would be 65% of board.Yes I just orders some Caps for my HDTV that I found it was cheap $10.99 shipping included.the only thing that looks good is the Screen itself.
            • jsog
              • Feb 2011
              • 220
              It would be a good idea to post a picture. Some things that look bad aren't problems.
              • soulripper
                • Aug 2011
                • 22
                Take my word for it most of it mainly mini transistors burnt halve way or the solder on th other side brown or black.not going to post picture for something so obvious as not to know myself is burnt it even smells that it fried.that would be doubting my own Intelligence.Besides burn is burn regardless and I already discarded of the Board, like I said thanks for you're help but Damage is too obviously Bad. I found this just wanted to see if it was a second chance.
                • Borse2008
                  Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                  by Borse2008
                  Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                  I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                  • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                  • There’s
                  07-15-2025, 04:55 AM
                • Rick_1234
                  LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                  by Rick_1234
                  Good evening, gentlemen.
                  I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                  To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                  https://drive.google.com/file/d/1L6S...ew?usp=sharing
                  Things I tried
                  - Bought a new AC adapter thinking that was the problem but the problem...
                  06-22-2024, 04:44 PM
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • DanPoka
                  Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                  by DanPoka
                  I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                  Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                  This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                  02-15-2025, 05:05 AM
                  by momaka
                  03-15-2023, 10:17 PM
