Dell E198FPb 19" LCD Monitor
+ More Options
Posts
  • soulripper
    • Aug 2011
    • 22
    When Connected to a Pc is works but it Flickers to different Color Tints,Green,Blue,Red constantly. Could anybody tell what might be wrong with it or what to check for.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Dell E198FPb 19" LCD Monitor
    Open it up, check for bad capacitors on the power supply / inverter. Check for bad brands of caps (check the FAQ for a list of 'replace on sight' caps) on the signal card and replace any that are suspect. Check the voltages out of the LDO regulators on the signal card.
    If you need further instructions, take pictures of the top and bottom of the poser supply / inverter and of the top of the signal card. Well lit, sharply focused pictures of at least 1000 x 1000 pixels are desired. Attach them using 'Manage Attachments' - below the text entry area. Do NOT post them inline.
    PlainBill
    • soulripper
      • Aug 2011
      • 22
      Ok, will do thanks.
      • soulripper
        • Aug 2011
        • 22
        I have open the Monitor and quite a bit is looking bad so decided not to persue this repair. not really looking to spend so much Money on parts.thanks for you're interest but it seems is not worth my time.
        • PlainBill
          • Feb 2009
          • 7034
          Ahh, how much money do you think it will cost? If you do a complete recap, you are looking at about $10 for caps and shipping.
          PlainBill
          • soulripper
            • Aug 2011
            • 22
            Is more than Caps other things look bad I mean over all it would be 65% of board.Yes I just orders some Caps for my HDTV that I found it was cheap $10.99 shipping included.the only thing that looks good is the Screen itself.
            • jsog
              • Feb 2011
              • 220
              It would be a good idea to post a picture. Some things that look bad aren't problems.
              • soulripper
                • Aug 2011
                • 22
                Take my word for it most of it mainly mini transistors burnt halve way or the solder on th other side brown or black.not going to post picture for something so obvious as not to know myself is burnt it even smells that it fried.that would be doubting my own Intelligence.Besides burn is burn regardless and I already discarded of the Board, like I said thanks for you're help but Damage is too obviously Bad. I found this just wanted to see if it was a second chance.
                • Rick_1234
                  by Rick_1234
                  Good evening, gentlemen.
                  Things I tried
                  06-22-2024, 04:44 PM
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • DanPoka
                  by DanPoka
                  02-15-2025, 05:05 AM
                  by momaka
                  03-15-2023, 10:17 PM
                • Jesus Coder
                  Issues Reviving Old Dell 2408WFPb Monitor
                  by Jesus Coder
                  I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
                  06-25-2023, 02:33 PM
