lg-ibm lcd
  • egaaaaay56
    • Jul 2009
    lg-ibm lcd
    i'm having problem with my LCD, after 30 minutes of use, power is turning on and off repeatedly, i unplug the power then plug it and its back to normal but only in minutes.
    need your opinion about this problem...
  • mariushm
    • May 2011
    • 3799
    Re: lg-ibm lcd
    Open it up, make pictures of the insides, post them here.
    Could be a bad solder join, a component getting warm and going out of spec, some resistor heating too much, swollen/bad capacitors and so on...
    A visual check can't hurt and may point out a possible fault
    • xZeroCool
      Biostar A320MH Ver 6x - Turning off on random seconds/minutes
      by xZeroCool
      Hi, I've got a Biostar A320MH Ver 6x. This motherboard basically turns off by itself even if I'm only in the BIOS Screen.
      Sometimes it will just turn on but no display, but if it POSTed it will show CMOS Fail everytime.
      The things I did to try fixing the problems with no luck.
      1. Changing CMOS Battery
      2. Reflash BIOS CHIP with latest bios file using desoldering method.
      3. Check voltages and it is just normal.
      Any ideas what the problem might be?...
      07-20-2024, 11:12 PM
    • Data45000
      LG 50PK950 - Turning off after 15 Minutes
      by Data45000
      Hi there,
      my old tv (~11,5 years) has a problem since 3 days.
      After 15 Minutens watching he is turning himself off - red light is on.
      When i try to turn him on - "click - clack" and going off immediately.
      After ~ 20 Mins i can turn him back on.
      on the Power Suppile Panal in the middle:
      I opend it, and i tested the three white resitors, all three 10,2 Ohm.
      The others are 0,2 Ohm.
      I tried to test the capacitors, but my device can only handle 99 yF.
      Is there any chance for me to save...
      04-06-2022, 03:00 PM
    • skimwam
      KRK Classic 5 popping and stops working
      by skimwam
      I have a pair of KRK Classic 5's running through a Scarlett Solo, and I have owned both for around 2 years. Never had any problems, but today I encountered an issue where the speakers will loudly pop, and then stop producing any audio. Restarting my computer and unplug / replugging the interface temporarily fixes the issue, but turning the monitors off and on again does not. Between 1-10 minutes after fixing it starts again. It seems like streaming music / video makes the problem happen less frequently then audio work in my DAW, but still occurs nonetheless. I tried unplugging...
      01-27-2024, 04:26 PM
    • Xan03
      Sony Trinitron E450 bad contrast 15-20 minutes after turning on
      by Xan03
      I have this CRT monitor, a Sony E450 made in 2003, that has the issue of a quite bad contrast and washed out picture after powering it on, it takes roughly 15 or 20 minutes to improve considerably but even then black levels still aren't quite ideal. This is with brightness dialed in via test pattern and contrast at 100% to get acceptable light output levels.
      Since it does improve after a warm up time is there a good chance of this being caused by capacitors and if so, what part to recap first? As far as I'm aware the vertical deflection area is where caps are stressed the most but...
      01-25-2021, 10:43 AM
    • Scoff
      LG55UB850V no picture or audio - flashing LED's help please?
      by Scoff
      Hi, I'm looking for some help with attempting to troubleshoot and hopefully repair my trusty LG55" TV.
      I'm reasonably comfortable working with electronics, but far from expert level! I have more experience with auto-electrics than anything.
      We recently had a power cut while the TV was on, and since then, when the TV is switched on at the wall, the red standby light comes on like normal. Then. when you press the power button on the remote or the TV to switch it on from standby, the standby light flashes 3 times and then goes out. There is no audio or video at...
      01-26-2022, 06:13 AM
