Acer x193w
  • tslater1989
    • Sep 2011
    • 11
    Acer x193w
    First off, its a vga only display, I got it for free and I am new to doing these kind of repairs.....please be patient with me!
    Problem: Plug display in...Power light turns on(orange) and in a flash the acer logo comes up and power light turns blue, then it imediately turns back off and repeats everything.
    Things look okay, except a few spots of solder were dull/looked unpolished like cast aluminum. I dont see any bulged tops of caps or bottoms for that matter on the power board or input board.
    Just looking to see if anybody else has had similar issues or idea for me to investigate, I have a fluke meter and soldering iron. Please help me out and more importantly have a great day.
    I will work on getting more pictures up soon(higher quality)
  • PlainBill
    • Feb 2009
    • 7034
    Re: Acer x193w
    Only two more pictures are necessary at this point.
    1. A clear, sharp, well lit picture of the top of the power supply / inverter.
    2. A clear, sharp, well lit picture of the bottom of the power supply / inverter.
    PlainBill
    • tslater1989
      • Sep 2011
      • 11
      Re: Acer x193w
      Thanks, I will have pics up tomorrow night. I'm going to bed, and I work 60 miles from home right now so I'm usually a busy guy. lol
      • tslater1989
        • Sep 2011
        • 11
        Re: Acer x193w
        So maybe I had a minute...thanks again!
        • Rtech
          • Jul 2010
          • 1095
          Re: Acer x193w
          The first thing I do with this model,is to plug in test Backlights,as the main fault with these is usually failure of the top backlight,normally due to one of the return wires burning out.
          • PlainBill
            • Feb 2009
            • 7034
            Re: Acer x193w
            Arghhh!!! Don NOT post pictures inline!!! Use 'Manage Attachments' - below the text entry area.
            There is a reason I asked for only two pictures. Angle shots showing a resistor are useless.
            PlainBill
            • tslater1989
              • Sep 2011
              • 11
              Re: Acer x193w
              oh, Sorry about that. I'll edit the posting.
              • tslater1989
                • Sep 2011
                • 11
                Re: Acer x193w
                Nevermind that, I cant find the edit button and I have to go to work. Thanks for your time though. Have a great day.
                • tslater1989
                  • Sep 2011
                  • 11
                  Re: Acer x193w
                  Anybody have any ideas? Again, I'm new at this and I want to learn. Any help is greatly appreciated. Thanks in advance. PlainBill, I'm sorry for not doing that in the format you requested, I'm trying though.
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Re: Acer x193w
                    This sounds like 'Two seconds to black'. Possible causes include bad capacitors, a bad inverter transformer, bad CCFLs or the wiring to the CCFLs, or a problem in the protection circuitry.
                    I've attached a picture. Two pins on one transformer have been circled in yellow. What is the resistance between those pins? Two pins on the other transformer have been circled in orange. What is the resistance between those pins?
                    Do you have any spare CCFLs, or access to another monitor that can be disassembled?
                    PlainBill
                    • tslater1989
                      • Sep 2011
                      • 11
                      Re: Acer x193w
                      505.4 (yellow) and 500.7 (orange) ohm's. I dont have anything around for spares, but I do have a friend who does have a few broken monitors.
                      • PlainBill
                        • Feb 2009
                        • 7034
                        Re: Acer x193w
                        Those resistances indicate the transformers are probably good.
                        Those look like standard connectors for the CCFLs. I'd suggesting borrowing one (or more) of your friend's monitors and try connecting the CCFLs in them to this inverter. They 'test' CCFLs can stay in his panel, all you are doing is hooking them up to your inverter.
                        If no combination of CCFLs will work with your inverter, it is time to start replacing caps. We know if a cap is bulging, it is bad. We know certain brands are very reliable. And we know some brands are not very reliable. I'd guess the caps with the black sleeves are Capxon. The green ones may be Lelon or Elite, neither of which are good..
                        PlainBill
                        • tslater1989
                          • Sep 2011
                          • 11
                          Re: Acer x193w
                          Thanks for your help, you strike me as a pretty intelligent person. I will get one friday and start testing.
                          • RJARRRPCGP
                            • Jul 2004
                            • 6301
                            Re: Acer x193w
                            I have the same kind of monitor (X193W) and it still works like a charm.
                            I believe the green caps are Samxon GK.
                            GK appears to be the best series used in LCD monitors.
                            I read something about GK here a while back and found nothing bad in particular about them.
                            I know I heard about GF before and was told to replace those pronto.
                            It looks like GK could be a lot better than GF.
                            But, I modded mine, just got rid of the back plastic grille. Just in case they're likely to go bad from heat.
                            ASRock B550 PG Velocita
                            Ryzen 9 "Vermeer" 5900X
                            Arc A770 16 GB
                            eVGA Supernova G3 750W
                            Alienware AW3423DWF OLED
                            • tslater1989
                              • Sep 2011
                              • 11
                              Re: Acer x193w
                              After hooking everything back up here is the full description of what happens,
                              1. Plug power in
                              2. Power led turns on (orange)
                              3. Power light turns blue
                              4. Monitor flashes on for a second fully lit so the ccfl's APPEAR to be working because the acer logo is vibrant and crisp
                              5. It all shuts back off
                              6. Repeats steps 2-3-4-5
                              The only monitor I was able to get ahold of died the same day when I turned it on so I have been fighting to get a different one. But I did see something that I was curious about.
                              In the red circle, its a tantalum cap(at least from what I have found online) that has a black top like the brown was burned away?
                              • PlainBill
                                • Feb 2009
                                • 7034
                                Re: Acer x193w
                                1. Plug power in
                                The part you circled is a ceramic cap. The picture isn't large enough that I can say much about the black spot on the top. It COULD be damaged; the black mark could be something from a QC examination; or could actually be a spark gap.
                                The symptoms you describe almost sounds like the inverter was drawing too much power. Have you checked the output voltages of the power supply while this is happening, in particular the 5 volt output? (Excuse me if this has already been answered, it's late and I don't feel up to rereading the entire thread.)
                                PlainBill
                                • tslater1989
                                  • Sep 2011
                                  • 11
                                  Re: Acer x193w
                                  I completely understand being tired, I have two little girls, one is three in a few months and the other is 5mo. I havent checked it but I will try to tonight. I will try to get a close up on that cap too.
                                  • teri3s
                                    • Oct 2011
                                    • 25
                                    Re: Acer x193w
                                    How has it been going with this repair?
                                    I caught my Acer X223w going out on me yesterday. The screen did a "white out" while I was using it. Now after I have been testing the power supply board the backlight seems not to want to come on anymore. The power board looks almost identical to yours. So I was curious as to how far you've gotten.
                                    • PlainBill
                                      • Feb 2009
                                      • 7034
                                      Re: Acer x193w
                                      You have a different problem. Ordinarily I like to see all problems with a given monitor in one thread, but troubleshooting two different problems in one thread is difficult for everyone, so I'm going to ask you to start a new thread.
                                      Start by taking three or four pictures of the monitor. One should be a top view of the power supply, the second a bottom view of the power supply, a third of the top of the signal card, and optionally, a fourth of the entire back of the monitor. It really helps if each picture is at least 1000 x 1000 pixels, well lit, and sharply focused. Pictures from directly above the board are best because the entire picture will be in focus.
                                      Then start a new thread with a description of the problem. Attach the pictures using 'Manage Attachments' - below the text entry area.
                                      PlainBill
                                      • bomcla
                                        • Nov 2010
                                        • 16
                                        Re: Acer x193w
                                        had the same monitor and had virtually the same symptoms. I also changed a lamp, but the monitor did not want to go. I tried to change the capacitors, but also nothing to do. I bought the power supply board in China for about 19 euros. Now the monitor works. I have pieces of the old card if you want
                                        • Ludmilaharhordina
                                          ACER A315-53G C5V01 LA-E892P rev2A the laptop turns on, but the display does not show
                                          by Ludmilaharhordina
                                          good afternoon.
                                          need help.
                                          the laptop turns on, but the display does not show.
                                          the laptop came to me from another workshop. visually broken USB 3.0 and soldered BIOS flash drive.
                                          I unsoldered USB 3.0 and flashed several different BIOSes, but it did not help.
                                          +VCC_CORE 0V
                                          +VCC_GT 0V
                                          +VCC_SA 1.03V
                                          +0.6VS_VTT 0.6V
                                          +1.0VALW_PRIM 1.0V
                                          +1.0V.VCCSTU 1.0V
                                          +VCCIO 1.OV
                                          +1.0VS_VCCSTG 1.0V
                                          +1.2V_VDDQ 1.21V
                                          +1.8VALW_PRIM 1.81V
                                          +1.8VS 1.81V
                                          +3VLP 3.27V
                                          +3VALW...
                                          04-02-2025, 08:51 AM
                                          09-06-2024, 05:27 AM
                                        • Victor Moreira Silva
                                          Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                                          by Victor Moreira Silva
                                          I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                                          Well, my decice specs are the following:
                                          Model: Acer Nitro 5 AN517-54-55T5
                                          CPU: Intel Core i5-11400H
                                          GPU: NVIDIA GeForce GTX 1650
                                          Motherboard: GH51G LA-L181P Rev:1c
                                          The symptom:
                                          When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                                          05-26-2025, 10:49 AM
                                          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 05:00 AM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
