Re: T240 Monitor Backlighting Issue
My problem is that the monitor produces a naty smell as if the board has overheated and burned. My transformer has visible plastic distortion due to heat. The monitor is working perfectly but the back panel at the are of the power supply is warmer than the other side and it smells badly.
I believe the transfmer has arched and overheated. Shou I replace it?
So far I have realized that the power supply boards IP-58155A have the TM-0918 inverter transformer and their power supply cord plugs perpendicular to the board.
At the begining of the thread there is another power supply board which I can not tell the part number, its power supply cord plugs in parallel to the board and they use the TM-10160 inverter transformer.
What is the difference between the two inverter transformers TM-0918 and TM-10160 ?
Both part numbers are available on ebay.
Are they compatible to each other?
Sorry for the thread necro, but i just wanted to thank everyone in this thread. I had the same problem as the op and this thread told me everything i needed to know to open up the monitor, test components, find that my problem was a faulty transformer and replace it. So now instead of however much it would have cost to get it repaired or having to buy a new monitor, i am only down £20 and am the proud owner of a new multimeter, new soldering iron and a fully working monitor.Leave a comment:
thanks sell door, to be honest i am just getting back to this project...Leave a comment:
We really need to know if when you switch it on NOW does the screen flash at all?
The link to the cfl is in budms signature 2 posts above.
Oh ho! you have managed to hide a fuse from us. Did you check the White one F102 in the middle of the board- Hiding behind the heatsink is a green torpedo fuse f 301 to test as well.
Test fuses - No power to board meter on ohms 200 one probe to each side of fuse
should be same as holding the probes together.
Next test after that is to turn on the power and test the voltage at each side of the green fuse with the black probe on chassis ground.Last edited by selldoor; 08-21-2014, 11:15 AM.Leave a comment:
thanks again for the replies, i did not take the panel apart farther. I saw a reference about the test lamps ,clf bulbs ?, so i'll search that out.
i will keep those two yellow caps in mind...Leave a comment:
So you took the panel apart to get the lamp assemblies? If I were you I would use two test lamps to find out if you have board problem or lamps problem.Leave a comment:
the large yellow cap near the heatsink looks like the top has started to dome slightly.Leave a comment:
So the backlights did come on for seconds and then black out? Then it may be bad lamps, bad MOSFET (the SMD with 5 legs on the bottom and big tab on top), bad inverter power supply section, bad BL_ON signal, ETC.
Can we see staright shot pictures of the top and bottom side of this Power supply-inverter board. It may be time to make two test lamps.Leave a comment:
1.006 K ohms, and 1012 K Ohms? If they are, then they are good.Leave a comment:
I scraped on the side of the pins and kind of pushed the points of the probes in a bit.
Got readings of 1.006 and 1.012. Don't know if it matters, this board is disconnected from the other board of the unit.Leave a comment:
The pin out of the windings in my post 49 is correct, so you may have to clean of the flux or resolder the pins of the transformer and try reading the resistance again.
It has the same pin out as this one:
http://s807.photobucket.com/user/bud...tml?sort=3&o=3Leave a comment:
Try the test again resistance should be around 1000ohms
Check you have the meter selector in the correct position - it goes all the way round on mine so
200ohms look pretty much the same as VAC600
Also try scratching the top of the solder joint with the probeLast edited by selldoor; 08-15-2014, 11:36 AM.Leave a comment:
Can you post the pictures of the top side of the board and the P/N as printed on the transformer so we can look for the pin out of the transformer?Leave a comment:
What scale do you set the Meter's Ohm mode to, 2K?Leave a comment:
so the black to pin 1 and red to pin 2 , shows it reading up to 1. and the same for 3+4...
i also looked at the solder with a mag glass and they seem ok , like the other solder points.
I do not see any discolored points or bad caps.Leave a comment:
Oops, set your meter to 2K Ohm scale and take the reading between pin 1 and 2, then pin 3 and 4. NO POWER to the unit of course. The solder joints look like they have some ring (hair line crack) around the pins.
For examples:
http://s807.photobucket.com/user/bud...?sort=3&page=1Last edited by budm; 08-13-2014, 03:26 PM.Leave a comment:
I am a total beginner. 1+2 , 3+4 is what i thought was to be checked. But the board being different puzzled me, still does. Why would they be different ? Would you tell me what looks bad about those 4 points ? I only have a multi-meter, how/what could i check for the whole board ? I could take this board to a PC repair place that did some solder work for me last month if i am not 'able' to. sorry for all the questions...Leave a comment:
by DqMagetzGood day!
I have a customer's laptop — Acer Nitro 5 AN515-54 (EH5VF - LA-H501P). It has a display on the external monitor and it's working fine, but the issue is NO display on the internal screen. I already replaced the eDP cable and checked the LCD connector pins.
Here are the voltage readings:- Input – 19V (stable)
- +LCDVDD – 3.3V briefly, then drops to 0V
- EDP_HPD – 3.3V briefly, then drops to 0V
- PCH_BKL_PWM – 2.2–5V briefly, then drops to 0V
- EC BKOFF# – 1.8V briefly, then drops to 0V
- PANEL_OD_EN – 0.3V
Is it possible that the EC chip is corrupted or damag...2 Photos -
by Rick_1234Good evening, gentlemen.
I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
https://drive.google.com/file/d/1L6S...ew?usp=sharing
Things I tried
- Bought a new AC adapter thinking that was the problem but the problem...-
by sew333My pc:
10850K stock 4800mhz stock Kraken X73 good temps
2x16 GB DDR4 GSKILL 3000mhz XMP
Seasonic Tx-850 Ultra Titanium
Gigabyte Rtx 3090 Gaming OC
Aorus Z490 Pro Gaming
1 TB SSD
4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
Power... -
by FercHeliXHi
There's this old LG 1510S LCD Monitor that had 2 issues, one with inverter board and one with image display (mainboard maybe), the issue with the inverter was that when i turned it on it goes off after 1 or 2 secs. and the problem was with the tuner caps on inverter board, after i changed the caps monitor stays on but there's another problem that if I turn it on by the power button, no signal message does not show on the screen, but if I let it stay on and disconnect by the power cable and connect it again the no signal message will appear, and one more thing...the 12V power is 17V before...-
01-28-2022, 08:20 AM -
This specification for the HP ProDesk DESKTOP BUNDEL (P5K01EA+M1N98AT) ProDesk 400 MT Intel Core i3-6100 + E232 monitor can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk DESKTOP BUNDEL (P5K01EA+M1N98AT) ProDesk 400 MT Intel Core i3-6100 + E232 monitor boardview and ProDesk DESKTOP BUNDEL (P5K01EA+M1N98AT) ProDesk 400 MT Intel Core i3-6100 + E232 monitor schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...09-12-2024, 03:28 PM
- Loading...
