viewsonic VG2021m Flashing Blue power LED no image
  • Medlock
    USN Salmon 573
    • Sep 2011
    • 26
    Hello and Greetings,
    I have a VG2021 monitor that was working fine until when coming out of standby (amber LED) it went to a dim flashing blue LED and no image. I have since replaced ALL Caps even though the 3x 220uf 25v 105's were only buldging, but have the same exact problem. I have used a DMM to check the +5 and +12 pins on the connector between the boards (power invert removed and benched) and Have 4.78 and 11.87 respectivly. I purchased the Cap kit from LCDalternatives and all are rubys. I have 21.2 volts across the main fuse (F200) of the DAC-12m033af REV 02a PCB. All connectors have been checked, No visable scorching. I have heard a 'chirping' coming from IEC? marked MP-1301 DCGM 0645 that coincides with the flashing LED. I have ordered a complete Power/inverter but was wondering in the meantime if you folks would have any other ideas.
    Thanks for your time
    Joe
  • Medlock
    USN Salmon 573
    • Sep 2011
    • 26
    Re: viewsonic VG2021m Flashing Blue power LED no image
    Ok Folks This is where i really could use your help.
    After purchasing the cap kit from the above mentioned co., They did not solve my problem, the folks there suggested that you all were the people to contact if I needed experienced help in the matters of LCD monitors.
    Ok as you have read I replaced all the caps in the first power board and was left with the same problem. I purchased a complete board and the problem remains. The symptoms are as follows:
    With the first power board before replacing any caps
    Amber standby went to flashing dim blue power LED when coming out of standby.
    No OSD No image when connected to computer.
    After replacing all caps (except large 150uf 400v):
    Same flashing blue LED except it was brighter
    Blue LED is on IMMEDIATLY when power plug is inserted
    Chirping was heard at the component (coinsiding with flash of LED) marked
    2804793700
    E115982 MP-1301
    DCGM 0645
    After inserting the new power board:
    Same Blue flashing bright LED Immediatly when plugging in power cord(sigh)
    Audible popping sound coming from internal speakers coinsiding with flash of LED (cannot hear the chirp)\No OSD No image.
    I did not have the protective metal cages that cover the boards on at this time. Just the boards mounted with all screws inserted and monitor supported by a wooden holder. -2 1x1's horizontal to surface of bench.
    Thats it guys, other than disconnecting all connectors and reinserting them and checking all PCB's for anything obvious thats all I can think of doing.
    Pictures can be submitted if need be, but I think they would be of little use at this point. Let me know if you would prefer to see them.
    power PCB Part # 12m033af rev 02a on both boards
    Chi Mei LCD Model A201P1
    Viewsonic VG2021m Bought 2005 Very light work as a Digital graphics and video editing computers monitor. Always off when not in use.
    Again Thanks for your time
    Joe
    • alexanna
      • Mar 2010
      • 1346
      Unless you have two bad Inv/PS,There’s three things left.
      I would start by removing the Ribbon cable from signal board to the LCD panel,Dose the behavior of the PLED change?
      Next unplug the Front panel switch from the signal board; you will not have a front PLED but do you get any indication that the back lights trying to come on.
      Or there may be a problem with the signal board.
      Pictures of the signal board will be needed, close up and in focus as close to 2000x2000 pixels as possible showing the entire board, using managed attachments.
      As a side note, this thread could easily be missed,for the members that concentrate mostly on the monitor section
      • Medlock
        USN Salmon 573
        • Sep 2011
        • 26
        thread moved to computer displays
        • learnmore
          Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
          by learnmore
          Hello Community!
          CASE DETAILS
          Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
          13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
          Tried inserting firmware on USB and left it in for a few hours, but no change
          03-03-2024, 09:49 AM
        • Focus2005
          HP OMEN 16-C0114NW – no image after replacing CPU Ryzen 7 5800H with 5 5600H and flashing BIOS
          by Focus2005
          Hello everyone.
          I have another HP OMEN 16-C0114NW laptop with serial number 5CD1501LJX. The original problem was as follows. The laptop could not load Windows and every time it threw a bluescreen - y - most often WHEA_UNCORRECTABLE_ERROR. The processor that was originally in it was AMD RYZEN 7 5800H MOBILE PROCESSOR - 100-000000295. I decided to replace it with a fully functional, used AMD RYZEN 5 5600H MOBILE PROCESSOR - 100-000000296, which I got from a donor board, on which it worked 100%. After soldering the processor, I also uploaded a new, fresh BIOS to it with the UBT2 program...
          05-01-2025, 05:41 AM
        • STKR123
          Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
          by STKR123
          As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
          I wonder if re-flashing the BIOS might be of any use here.
          As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
          There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
          11-03-2024, 06:58 AM
          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
          09-12-2024, 02:20 PM
          Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
          This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
          09-07-2024, 05:50 AM
