IISonic IIEM989 weird problem
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    I just picked this one up today. Monitor will not work unless one of the buttons (anything except Power) is kept pressed. No obvious bad caps in the power supply or on the logic board (although they're all Lelons), voltages are all in check, inverter ok, lamps ok.
    I'm suspecting a bad EEPROM but i don't have a programmer for those... and even if i did i don't have a dump to write to it. Any ideas before i order a new logic board? I found one here: http://www.ebay.co.uk/itm/55-L21V2-0...item5889130fd7
    A working TV? How boring!
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: IISonic IIEM989 weird problem
    It pays off to triple check... I checked all wires that go to the keypad and on the 4 buttons i got 3.3v when they are not pressed, only on the power button i had 0.3v... So i disconnected the keypad and the power button line also went to 3.3v. Momentarily shorted it to ground - the monitor came on and STAYED on.
    Looks like i just have a bad power button. I have a few handy, gonna replace it and let you know how it went.
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      Fixed, albeit in a different way. The power button exhibited no appreciable leakage when measured with a multimeter set on resistance, so i used a 1k resistor from the 3.3v rail to make a better pullup. Works fine.
      The voltage does however fluctuate from 3.2v to 2.5v on the button so there is a bit of leakage there (while the 3.3v rail is rock solid), but that's not a problem - anything between 2.0v and 3.3v is "high" in TTL logic.
      • chaos-theory
        Nitro rx580 very weird problem, VCORE and EN
        by chaos-theory
        Hello!
        I have this very weird problem, I got this rx580 nitro saphire and the fans don't even spin but the saphire logo is lit.
        All voltage rails are present except for VCORE at the coils, then I started checking NCP81022 and it has voltage but vdd pwrgd is missing, enable EN is missing it shows 2.5ohm, everything seems fine, i tried checking the back of the card, to see where the enable pin goes, i dont have a schematic so i started touching randomly until i measured a resistor on the back and the fans started spinning, now I was amazed like what is wrong here? So I thought it's a...
        08-17-2024, 04:56 PM
      • badboyzzz
        A2229 ipad pro 12.9 4gen strange problem Logic Board related charging but no usb data
        by badboyzzz
        I have a strange problem with my iPad Pro 12.9 4Gen / A2229. When I start the device, it stays on the Apple logo, but when I heat the back of the device with a hair dryer, the device boots, but this time there is an interesting problem. The iPad is charging, but there is no USB data on the computer. The USB charging port has been changed and the chips seem normal, but I have given it to 2 different Apple services in Latvia, but the repair could not be done. Is there anyone who can help with this? Can someone support the repair by sending only the motherboard within Europe? Thank you.
        12-28-2024, 02:11 PM
      • c.daniel
        Lenovo V310-15IKB weird bios problem...
        by c.daniel
        Lenovo V310-15IKB Type 80T3 laptop, i7 7th cpu with dedicated Ati video
        sn LR09493E
        MB DAOLV6MB6F0 REV. F
        The laptop was working fine, the only problem was that when I turned it on, the screen was hard to turn on, it would wait for about 30-40 seconds before an image appeared on the screen.
        Initially, I updated from windows to Intel Management Engine 11.8 Firmware, restarted, everything was fine.
        Then I updated the bios, also from windows, to the last vs, vs 46. It restarted, those lines with bios update progress appeared, restarted and that's it, since then...
        08-22-2025, 05:39 AM
      • sorrowfulfloyd
        Samsung UE32J5373AS Weird LED Problem
        by sorrowfulfloyd
        Hi all, first time seeing a LED problem this weird so I wanted to discuss with y'all before handing back this TV to my costumer.
        This TV came to my shop with no picture but sound present. So I thought ok this must be a LED problem and I shine a light with my phone's torch amd and yup I see the image. So I disassemble it and before changing the LEDs I check the motherboard voltages (this unit works with an external 16V DC brick) and I see 54 volts at the input pin of LED strip, considering this TV has 2 strips of 7 LEDs which at 3~ volts it must be equal to like 42 volts. I remove...
        12-23-2022, 07:00 AM
      • theone111
        by theone111
        3. Problem: TV shuts down
        07-22-2024, 10:36 AM
