viewsonic vx 2235wm
  • nickmatine
    • Jun 2010
    • 48
    viewsonic vx 2235wm
    Hi guys
    i have a viewsonic VX2235wm with 2 burn transistor 9973gh. has anyone cross reference for this
    thanks
  • pedro
    • 199
    • AUSTRALIA
    Re: viewsonic vx 2235wm
    Possibly your device is this http://www.alldatasheet.com/datashee...S/SSM9973.html
    Friends don't let friends buy Samsung ....
    • connorcc2005
      Thermistor specs and cross reference
      by connorcc2005
      I'm getting some conflicting information and thought I'd toss it out to all of you for input.
      What I have is a TTC-104 thermistor. This is part of a temp sense circuit that will drive a small 12v fan to cool components mounted to SMPS heat sink.
      The physical diameter of the piece is 5.1mm measured with a caliper.
      Other than what you see in the pic, there is no other writing on the part.
      My research of the TTC-104 says it should read 100 ohms at 25C. Out of circuit measurements have it at approximately 100k. It does change as the temp changes....
      06-16-2022, 04:16 PM
    • raregtp
      Voltage regulator cross-reference
      by raregtp
      Hey all....hoping someone can help me with this. I have a couple voltage regulators I'm trying to cross but not having much luck.
      The first is:
      A1
      AS1117L-18
      B0640 25
      The second is:
      A1
      AS1117L-33
      B0640 28
      I know the AS stands for Alpha Semiconductor, and I think I've found a datasheet for the AS1117L-33, just can't find anything for the -18. Ultimately I'm looking to cross these over to parts that I can get now, as all I'm finding similar are AZ1117 regulators.
      If anyone can assist...
      03-15-2020, 11:12 PM
    • lostone
      Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
      by lostone
      Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
      First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
      When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
      05-19-2024, 11:40 AM
    • jasko_jacker
      cross reference tps51285a
      by jasko_jacker
      I try to substitute the RT6575B with TPS51285A,
      it seems to work but it is slightly warmer, the board does not start due to other problems so but not sure if replacement is possible...
      12-07-2021, 01:49 PM
    • speaktorob
      Reference Nvidia GTX 980 ti - looking for a new shroud
      by speaktorob
      So a while back, to deal with the fan noise of the old blower style shrouds on the reference cards, I chucked it and installed the monster that is a Raijintek MORPHEUS 8069, with a couple Noctuas on it. Did the job but quite unwieldy tbh.
      Anyone know which boards would have a compatible shroud for it? I know the EVGA used the reference board but wondering if any other manufacturers did. I want to put something sensible back on it, but I'm having a hard time getting hold of even a faulty reference board for a reasonable price.
      03-22-2024, 03:00 AM
