Iiyama ProLite481S - Bad Caps Found - Advice Please
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Iiyama ProLite481S - Bad Caps Found - Advice Please
    Originally posted by Pull9Gs
    Ordered the above shopping list with PlainBill's recommendation and swapped all the caps out yesterday morning - see attached photos.
    Good job on the repair.
    IIRC, I think PlainBill uses an egg carton too for screws, caps, etc.
    --- begin sig file ---
    --- end sig file ---
      by momaka
      03-12-2025, 03:42 PM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • Paxman_Swede
      by Paxman_Swede
      Hello!
      01-14-2025, 09:51 AM
    • captain150
      by captain150
      03-16-2025, 07:34 PM
    • Foetuss
      Gigabyte GA-6OXT :: caps question
      by Foetuss
      Good evening
      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
      But I was also suprised about the bigger boys, which are 330µF 25V.
      Could it be they used 25V caps because they were cheaper / available at that time?...
      02-11-2025, 12:22 PM
