eMachines Le1938-Need Help
  • Addikt
    • May 2011
    • 7
    Hello everyone my name is Aaron. I am new to these forums and I am seeking some help.
    I have common knowledge on circuitry, but I am far from experienced.
    What I have is a eMachines Le1938 19" Widescreen LCD monitor. The problem I am having with the monitor is that it will display perfectly, then display no signal detected. The monitor is not powering on and off, it is simply losing signal. There is a pretty stand out hum coming from the inverter. I have disassembled the monitor and have the board out of it. I just have no idea what to look for.
    Odd Note* When the monitor displays my desktop if I press any menu key on the side of the monitor it will hold the picture until I release it. When I release the button, it loses the signal again and begins to cycle display/no signal again.
    Thanks in advance, Aaron.
    In This picture I have highlighted the portion where I think the sound is being created from.
    The Back Side of the board
  • PlainBill
    • Feb 2009
    • 7034
    Re: eMachines Le1938-Need Help
    A few points:
    1. In the future, don't post pictures inline. It causes problems for those who have a slow connection and irritates the rest of us.
    2. The general composition of the picture is good, but we really need something closer to 2000 x 2000 pixels to see details.
    3. There are no obvious bulging caps, but many manufacturers have learned how to make caps that fail without any obvious signs. What brand are these?
    4. The symptoms point to a problem with the signal (logic) card or bad capacitors on the power supply, with the former being more likely.
    PlainBill
    • Addikt
      • May 2011
      • 7
      All the caps appear to have "Su'scon" written on them. I apologize about the pictures.
      Here are the larger pictures.
      Back Side of Board
      Front side of Board
      • PlainBill
        • Feb 2009
        • 7034
        Back Side of Board
        Front side of Board
        My brain cells aren't up to speed this morning. That was probably the cause of the strange omelette I served my wife at 6:00 AM.
        Check the FAQ; Su'scon are on the 'Bad Caps - Replace on Sight' list. I suggest replacing them with low ESR name brand caps such as Panasonic FM, FC, or FR series; Nichicon, Rubycon, and United Chemicon have equivalent high quality low ESR types. Don't go down to Radio Shack for the replacements.
        We prefer to have pictures hosted on site, not off site for several reasons. Use 'Manage Attachments' (below the text entry area) to attach them.
        PlainBill
        • Addikt
          • May 2011
          • 7
          PlainBill I appreciate your help in advance.
          Now if one of the capacitors or several of them were out together.
          Would it cause my screen to display, and not display, display, and not display? It is not losing its power, it is simply losing its power to display. Also when it loses its display ( displays no signal found ) that is when the humm appears. When the screen is displaying, the humm goes away.
          Also I have counted 8 capacitors on the board.
          220 UF, 35V
          47 UF, 25V
          1000 UF, 10V
          470 UF, 25V
          680 UF, 25V
          150 UF, 35V
          100 UF, 450V
          47 UF, 25V
          Is there precautions I need to take if/when I go to remove them all?
          Do you have a rough cost in your head for the following list? (Ball-Park)
          Edit* I would like to replace them with something that will provide a long life. The monitor is a pretty nice display, I would like to hang on to it if I could.
          • retiredcaps
            • Apr 2010
            • 9271
            If you are in the USA, it should cost around $10 including USPS 1st class shipping and you get the caps in about 2 business days.
            See
            https://www.badcaps.net/forum/showpo...8&postcount=87
            --- begin sig file ---
            --- end sig file ---
            • PlainBill
              • Feb 2009
              • 7034
              220 UF, 35V
              47 UF, 25V
              1000 UF, 10V
              470 UF, 25V
              680 UF, 25V
              150 UF, 35V
              100 UF, 450V
              47 UF, 25V
              You bring up a good point. The answer is 'It could'. One possible explanation is excessive ripple on the power line to the signal (logic) card.
              An analogy would be if a customer brought a car in to a mechanic. The complaint was poor handling. Possible causes would be bad shocks, bad alignment, or tires out of round. The mechanic notices the tires are seriously under-inflated. The first step would be to properly inflate the tires and road test. It could be a simple, profitable fix - $5 for air and $100 for labor. If, on the other hand, the tires had been properly inflated it would be time to check other things.
              If you had reported the caps were Nichicon HD series, I would have suggested checking voltage regulators on the signal card. One problem with that as the first step is you probably don't have the equipment (an oscilloscope) to check the power bus properly.
              PlainBill
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                If you do end up replacing the capacitors, the 100uF, 450v one can be left alone. Those fail very rarely.
                • Addikt
                  • May 2011
                  • 7
                  My philosophy would be, if you want to do it the right way, do it the right way.
                  Since I am going to replace a potential 7 capacitors, I might as well do all eight of them. I am very interested in prolonging the life of the monitor. If it was a 15" CRT I wouldn't be as worried however, it is a 19" widescreen. Which isn't the best of the best anymore, but it makes me happy.
                  @PlainBill
                  Oscilloscope - sure don't.
                  I am following your words very closely. From your post count/age I am making an assumption that you are probably one of the most knowledgeable around. Once again, an assumption .
                  Could the pressing of any menu play into that? I stated previously when the screen is lit I can hold down any of the menu keys and it will hold the picture. As soon as I let go of it, it loses its signal.
                  When pressing any menu key, could that be altering the electrical path and perhaps changing the power on the inverter somewhere? So the capacitor(s) that are probably my problem are receiving that extra umph that they need to power the display.
                  Sorry for all the questions, every day is a learning day. I know for fact, I work in retail.
                  • Addikt
                    • May 2011
                    • 7
                    I am back at it again with this monitor. Upon further investigating, when I unplug the LCD (glass) the power light stays on, no hum, and my computer detects the monitor. Obviously I have just removed the LCD panel from the unit. So technically its recognizing the inverter and logic board only.
                    Ideas?
                    • PlainBill
                      • Feb 2009
                      • 7034
                      I have a couple of questions. When the monitor fails, does anything happen other than the hum and the 'No Signal' display? Do the backlights and the power LED stay on?
                      The obvious difference is with the LCD panel disconnected the power supply has less load.
                      PlainBill
                      • Addikt
                        • May 2011
                        • 7
                        Nothing else happens, the power LED stays on and the screen displays the no signal screen until it briefly returns to displaying the computer's desktop.
                        • alexanna
                          • Mar 2010
                          • 1346
                          Ideas?
                          Another question when you say you disconnect the monitors glass, is that the 30 pin ribbon cable and all of the CCFLs?
                          • PlainBill
                            • Feb 2009
                            • 7034
                            Alexanna, like your signature. It's similar to my 'Three things to check to know if you are having a good day.'
                            1. When you first wake up, check your big toes. If there is a tag attached, it doesn't look like this is going to be a good day.
                            2. Check the obituary section of the paper. If you are mentioned, things are REALLY looking bad.
                            3. Go down to the Post Office. If your picture is on a 'Wanted' poster, you can be certain you are having a bad day.
                            PlainBill
                            • Addikt
                              • May 2011
                              • 7
                              Correct, that is a complete removal of the LCD screen from the main unit.
                              • alexanna
                                • Mar 2010
                                • 1346
                                If you haven't already it's probably time to consider spending the 10 bucks on some good capacitors.
                                But there is one thing I would like you to try.
                                Try hooking everything up but the 30 pin ribbon to the LCD.Power on.
                                Dose the LCD recognize a signal?
                                What do the backlights do?
                                Can you turn the monitor on and off with power button?
                                • Lex
                                  • Jun 2011
                                  See
                                  I need to order the capacitors for this monitor. Is there a kit at badcaps.net?
                                  Thank you.
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    No kits but you can order caps.
                                    Despite hordes of people showing up with bad screens lately BCN was originally intended for motherboard issues so he probably does not stock all sizes needed for screens.
                                    - You'll have to look to be sure.
                                    https://www.badcaps.net/store/
                                    Mann-Made Global Warming.
                                    - Dr Seuss
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      From what I know, badcaps.net started for motherboards. Thus, you will not likely find a premade kit for lcds.
                                      There are 3 reasons why you should make your own list.
                                      1) It is often cheaper than buying something premade.
                                      2) Manufacturers can and do make revisions to boards while keeping the same lcd model number. Premade kits might not match your board.
                                      3) You get to choose your own caps as you might have preferences or want spares.
                                      • Lex
                                        • Jun 2011
                                        Thanks for the info!
                                        • sew333
                                          Pc shutdown, monitor flickered with no signal after 10 seconds
                                          by sew333
                                          My pc:
                                          10850K stock 4800mhz stock Kraken X73 good temps
                                          2x16 GB DDR4 GSKILL 3000mhz XMP
                                          Seasonic Tx-850 Ultra Titanium
                                          Gigabyte Rtx 3090 Gaming OC
                                          Aorus Z490 Pro Gaming
                                          1 TB SSD
                                          4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                                          Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                                          Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                                          Power...
                                          02-22-2022, 10:27 AM
                                        • wattage
                                          AOC AG493UCX 49-inch monitor - Firmware request
                                          by wattage
                                          Hello Badcaps Community,
                                          The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                          07-13-2025, 04:41 PM
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • AstutePauciloquent
                                          Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                                          by AstutePauciloquent
                                          Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                                          I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                                          11-23-2023, 11:02 PM
                                        • Rick_1234
                                          LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                                          by Rick_1234
                                          Good evening, gentlemen.
                                          I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                                          To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                                          https://drive.google.com/file/d/1L6S...ew?usp=sharing
                                          Things I tried
                                          - Bought a new AC adapter thinking that was the problem but the problem...
                                          06-22-2024, 04:44 PM
