Re: zerox 22" lcd psu help
Check ZD203 on the underside of the board
Also check Q201 for short
Have had both of these go on one board which caused the fuse ,thermistor and resistor R217 to blow
I just got my fuses today and a new 100uf 400v cap and i replaced the thermistor that had blown.
Now my new problem is that everytime i give power to the pcb the main fuse blows? I give upthe damn thing
Um, never heard of a transistor rated in microfarads.
That sound indicates the transistor is working but the power supply is in protection mode. That usually happens when something's shorted in the secondary side. It could also be a bad controller startup cap so try replacing that too. It's a 50v cap, usually 10 or 22uF but can be other values, next to the SMPS controller IC.Leave a comment:
I deffinatly used the right fuse im thinking that the thermistor got damaged when it blew the first time around.
Im having a look through my bits and i need a 33uf 275v primary switching transistor but as of yet im only finding 22uf's and 47uf's but theres time yet.
Im wondering if the primary switching transistor is causing the tick, tick, tick sound?Leave a comment:
Just jumper it for now, it doesn't do much except protect the mains from the spike that occurs when the primary cap is charged.
If the thermistor blew the fuse should have too. Are you sure you used the same rating of fuse? Anyway, this indicates a short in the primary. Either the primary switching transistor or the bridge rectifier.Leave a comment:
Just done some reserch and the NTC201 054 that i blew is a Thermistorim still quite new to this game.
Now im just wondering where to go from here, what to replace it with and/or where to get a replacement from.
How also can i tell what rating i need and how to check them as the only writing on the blown one is NTC 054.
Cheers guys in advanceLast edited by swampy; 06-02-2011, 05:36 AM.Leave a comment:
Just replaced the main F201 fuse and the 400v cap and ive just blown the NTC201 054 ceramic cap.Leave a comment:
Yes, but the 100uF cap has nothing to do with your issue.Leave a comment:
Cheers sabre504 thats great help
Would it be ok to swap the 100uf 400v cap for a 120uf 400v cap?Leave a comment:
Forgot i had this may be of some helpLeave a comment:
You don't need to change the cap. And you can substitute a regular glass fuse with the same specs, there should be enough room for a fuse and a fuse holder.Leave a comment:
Does anyone know of a good supplyer in the uk of these fuses T3.15A/250VAC.
On my board it is a little red box.
Im also im going to change the c201 cap (400v 100uf) as that was what i was testing when i got the blow out.Leave a comment:
Following on,F203 feeds the +14v to both the connector,and to the inverter side of the cct,so when you get it running again,one test I would do would be unsolder one side of the fuse,and then measure both the outputs,and see if the fault may be in the inverter side.Leave a comment:
Im not too bad with caps its just everything else
I've got another monitor that ive changed every cap in but its still having trouble to kick in, (but thats another thread)
Confirm that of the 4 x 680uf caps,the left hand pair,have their negative side facing the other pairs negative side ?? ( cannot see if they are from the photo).Leave a comment:
Thanks for the help so far peeps
I've just tested the voltage on the pins and this is what i get,
on the +14v pins im getting a bouncing reading from 0 to 1.5v
on the +5v pins im getting a bouncing reading from 2 to 3.5v.
I think i've just fubar i got a spark while i was testing the c201 cap (400v 100uf) and now it smells of sulphur and im not getting any reading at all
I've just blown the F201 fuse T3.15A/250VAC.Leave a comment:
I've just blown the F201 fuse T3.15A/250VAC.Last edited by swampy; 05-17-2011, 02:48 PM.Leave a comment:
I forgot to say the board is a Mirage PI-190DTLB board.Leave a comment:
I've changed the start up cap and its still ticking? and the dc voltage from the pins on the connector on the right hand side of the power board is still fluctuating.
2 of the pins are 14+v and 2 are 5+v.Leave a comment:
by RassHello, could you help me with the boardview of an ASrock X670E Steel Legend? I have a project to assemble a PC from scrap parts. My last purchase was this motherboard and I want to try to repair it as much as possible. Any help is acceptable and welcome. Always grateful for the help Greetings
by MiguelitowsHi Guys,
I am new in electronics repairing. Do anyone have Asrock b550m steel legend schematic and boardview if can with front and back layer file?. Thank you in advance guys!...-
03-21-2025, 05:44 PM -
by karlp028I've got an ASRock B450 Steel Legend that I'm trying to diagnose for no reaction to the power button.
The SIO receives the PWRBTN# signal and sends PSOUT#, but the CPU doesn't return SLP_S3# so nothing further happens. I have been looking around the board trying to figure out why and I happened to touch the STEP-DOWN CONVERTER NB685GQ-Z (UP10 in photo) which was VERY hot (like burn your finger). This seems to provide VDDP_S5, and indirectly, VDDCR_SOC_S5, which the CPU needs in order to handle the startup signals.
The VCC voltage powering the converter does not look right....1 Photo -
by Gamer128Kindly share boardview of ASRock X570 Steel Legend!!
12-30-2024, 10:16 AM -
by sunofra78Would anyone know what this component may be? It's on an ASROCK B460 Steel Legend Gaming PC Motherboard. The writing on it is 29 7B / 43N.
Thanks....1 Photo - Loading...
