Viewsonic VA912 logic board issues
  • sylvester328
    • May 2011
    • 3
    I have two broken VA912 with same symptom of black screen.
    I replaced the caps on the inverter board for the first one and it then worked right away.
    However, when I did the same on the second one, symptoms remains. I swapped the parts with the first monitor. I can conclude that it is due to the main logic board.
    I can see the image when I shine light on the LCD panel. It has to be the backlight not coming on.
    I examined the board and could not find amy bulged caps. Any pointer where I should look or caps that I should change?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Viewsonic VA912 logic board issues
    1) Start by posting clear focused pictures using the manage attachments button below the text area. Do NOT post pictures inline or offsite.
    We want picture as close to 2000x2000 and like this.
    https://www.badcaps.net/forum/showpo...94&postcount=1
    2) Do you have a multimeter? If yes, there might be a blown fuse in the inverter section of the board. Or a shorted mosfet or transistor. Also, you can measure the backlight off/on pin to see if the voltage changes when you press the on/off button.
    --- begin sig file ---
    --- end sig file ---
    • sylvester328
      • May 2011
      • 3
      The inverter board and the logic board are in the picture.
      The inverter board has no problem as it works when coupled with a good logic board.
      I found the schematics around the connector between the two boards (attached). Pins 1,2 are 12Vcc, Pins 3,4 are GND and Pins 5,6 are 5DVCC and all appear normal. I therefore tried to measure pin 7 and pin 8 in the connector. I doesn't seem to get a proper reading for both pins no matter I tried a good or bad logic board (zero readings). But I am pretty sure the good logic board works as I can hear the soft high pitch noise from the inverter while the bad logic board doesn't. What should I expect with those pins?
      • Rtech
        • Jul 2010
        • 1095
        [QUOTE=sylvester328;164181]I have two broken VA912 with same symptom of black screen.
        QUOTE]
        You may be getting confused between Logic and combined PSU/Inverter !!!
        If you can see an Image then the LOGIC board( the one on the right in your picture) is NOT faulty.The problem is with the PSU/Inverter.
        • Rtech
          • Jul 2010
          • 1095
          Measure the resistance of the secondary windings on the Inverter Transformer,the ones at each end.
          • sylvester328
            • May 2011
            • 3
            I am NOT confused. The Inverter board is the one with the main voltage input. The one on the right in my picture (the logic board) is the one being faulty. I can guarantee that. As I said in my original post, I have two identical monitors. One is now working and the second one is not. I have been swapping parts between the two and pinpointed that the logic board is the culprit. With the good logic board, the monitor works with any one of the inverter boards. However, with the bad logic board, the monitor does not work with either of the inverter board.
            I am now suspecting the 5DVCC to 3DVCC regulator circuit on the logic board. Will test it tomorrow.
            EDIT: Hmm.. No. It can't be 5DVCC to 3DVCC either. The RTD2523 takes 3.3VDC and 2.5VDC as well. That parts seems working (as I can see the image).
            • PlainBill
              • Feb 2009
              • 7034
              Aha!!! The light dawns!! Let's call them signal (logic) card 'G' (for good) and 'B' for bad. With 'G' the backlights are on and you can see the display. With 'B' the backlights are off, but you can see a dim display.
              The area you are interested in is pins 7 and 8 of CN1, and the signal lines VRMT and VBRI. Those control respectively the On/Off and Brightness signals to the inverter. And what is more, there is often a third line from the processor chip which switches power to the LCD panel, and often a fourth which controls the power LED. Since you can see a dim display on the 'B' card it is likely all of those outputs are correct, it's the support components that must be checked.
              PlainBill
              • ohren
                by ohren
                09-08-2023, 05:24 PM
              • Yanleb
                LG 60PK550 Logic Control Board EBR63450301
                by Yanleb
                Hi all, I just want to share the repair of my 60PK550-UA TV set.
                The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                C57: 3.30V
                C61:...
                07-20-2023, 12:38 AM
              • lostone
                Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                by lostone
                Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                05-19-2024, 11:40 AM
              • jb_Bak
                by jb_Bak
                CN6401
                Pin 01 NC
                Pin 02 NC
                Pin 03 "BL_ON": 0V
                Pin 04 "N/C"
                Pin 05 "STBY 3.3V": 3.5V
                Pin 06 "GND": N/C
                Pin 07 "AC_OFF"...
                09-27-2021, 04:52 PM
