Adjustment in LCD Panel
  • pavithra_uk
    • Nov 2010
    • 44
    My Toshiba Satellite M35X has LG.Philips LCD Panel.
    Question is this:
    There is a tiny Variable resistor in Panel board to adjust something.. it never marked for purpose. what its purpose ?? Adjusting contrast ?
  • PlainBill
    • Feb 2009
    • 7034
    Re: Adjustment in LCD Panel
    Question is this:
    It's probably used to adjust one of the voltages used to drive the individual pixels. If you want to do something very foolish, try adjusting it.
    PlainBill
    • pavithra_uk
      • Nov 2010
      • 44
      PlainBill
      I adjusted it and nothing happens or no differance in pictures. so I reset it back to original position.
      Like to know what happens it adjusted ?? low voltage or high voltage effect on pixel drivings..
      a very small change in value can panel to be died ??
      • japlytic
        • Oct 2005
        • 2086
        Such controls are factory adjusted and in many cases, adjustment is not specified in servicing literature.
        • Rtech
          • Jul 2010
          • 1095
          You see what happened, you moved it and India won the cricket World cup...never mind.
          • pavithra_uk
            • Nov 2010
            • 44
            because of politics infected in cricket..
            otherwise we win the cup
            • tronxkid
              • Jun 2011
              • 20
              What is cricket?????
              • PlainBill
                • Feb 2009
                • 7034
                What!!! You don't know how to use Google???
                PlainBill
                • alexanna
                  • Mar 2010
                  • 1346
                  We are developing a new game here in the Midwest states it's called β€œCicada”
                  The only problem is its going to be difficult to get good at it; they only show up around every 17 Yrs.
                  • Rtech
                    • Jul 2010
                    • 1095
                    Now..I'll have to Google.....'Cicada'....!!
                    • tronxkid
                      • Jun 2011
                      • 20
                      PlainBill
                      whats google?
                      • howardc64
                        LG 49UJ6500 LCD panel lighter band that goes away
                        by howardc64
                        49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                        Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                        02-19-2023, 12:13 AM
                      • triplefour
                        SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                        by triplefour
                        TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                        tcon is built into mainboard.
                        Only one cable goes to panel boards.
                        there is a cable from one panel board to the other that links them.
                        cost cutting measure that results in us having harder time to diagnose.
                        removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                        used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                        07-28-2022, 07:59 PM
                      • Storyteller12
                        QN55Q60R Service Menu Panel Help
                        by Storyteller12
                        I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                        I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                        I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                        the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                        01-13-2024, 01:57 PM
                      • maneatingmonkey
                        Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                        by maneatingmonkey
                        I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                        There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                        03-27-2024, 07:17 AM
                      • KYBOSH
                        Samsung UN50TU8000 - Dead Panel Forensic Questions
                        by KYBOSH
                        I came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
                        When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
                        When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
                        Later I checked for shorts on the panel PCB boards but could not find anything.
                        When I took a look with the FLIR i noticed the 2 resistors...
                        08-10-2024, 08:39 AM
