Got an HP 1740 with the exact board playman posted the pics on. Need the schematic for 48.L1G02.A01 Benq board. That rev number at the end makes all the difference as there are subtle difference between rev numbers.. The schematics and board layouts and component designated numbers are different. Does anyone know where I can get the correct schematic and board layouts? Thank you
Need correct schemtic
Re: Need correct schemtic
Try this link to elektrotanya.com. This site is just one to try in a list of others.
Let the rest of the folks on here know if this helps ya at all.
Have A Great Day
lcdman
http://elektrotanya.com/hp_1740a_sm.pdf/download.html
by ValtekkenSpecs:
- CPU=AMD Ryzen 5 3500U
- GPU=(integrated) Radeon Vega Mobile
- RAM=8GB (2x4GB, a 4GB set is soldered), DDR4; 1x4GB Ramaxel, 2400MT/s, RMSA3310MJ86H9F-3200; 1x4GB Micron, 2400 MT/s, no part number (soldered)
- Storage=512GB, NVMe SSD, hfm512gdhtni-87a0b
My issue isn't massive, but I'd like to get this solved since I'm trying to fix a friend's laptop.
A botched BIOS update by Lenovo bricked this laptop, so I used my BIOS programmer to reflash the BIOS on it and saved it from an early demise. All is good now, but the BIOS reports the S/N, MTM and UUID... -
by objecttothisI had a desktop form factor mini-server die on me a few weeks ago. Through my initial diagnostics, I was convinced it was the motherboard because when I shorted the Green wire on the ATX connecter, the multimeter gave me all the correct voltages on the various pins of the ATX connector and 5VSTB was also correct. To my surprise the replacement motherboard wouldn't turn on with the case power button either. I threw in another PSU and it turned on right away. This is an 80 Plus EVGA 430W PSU with PN:100-W1-0430. I pulled the cover off and don't see any immediately obvious blown caps or scorch...
by NoRelaxGood day,
In my hands I have a Thinkpad T14 gen 1 (20UD002BIX) showing sporadic BSOD issues caused by failing onboard soldered RAM. I suspect disabling the onboard RAM via a bios mod would do the trick.
The laptop has already the latest updates as well as latest bios 1.51 as of today.
I informed myself in an attempt to DIY my way to victory but it left me with more questions than answers. This is not a BIOS request, what I really need is somebody to verify that the following procedure is correct.
Step 1: grab a bios image:
- Method 1: from the official website:... -
by harpI noticed that in schematics is used random triac simbol, where on gate side is T1 or T2. I know it pass current in both direction, so generaly it is not important, but ask for consistency to learn correct. Why is developed this two way of marking if symbol is standarized?...04-27-2024, 06:26 PM
by FlyviewHi!
Happy to be part of this forum for my first post!
Short story:
I believe my dad's UX51VZ has an incorrect bios (v207) for a UX51VZH flashed onto it. I'm not quite sure what the differences are between UX51VZ, UX51VZA, and UX51VZH. The serial number of this machine is D5N0CY845932229 and comes up as a "UX51VZ-DB103P" when checked on this ASUS website. All of the bioses can be found at this ASUS website.
1) Do I have the correct bios or should it be the v205 for UX51VZ? Is there something I can check inside the machine to make sure?
...03-31-2024, 11:56 PM - Loading...
