Burned Backlight - Samsung 943NW
+ More Options
Posts
  • Badcappy
    Banned
    • Aug 2007
    • 52
    Re: Burned Backlight - Samsung 943NW
    Hm, ok thank you very much.
    I will order all the parts together and try to email ccflwarehouse.com, lets see what happens.^^
      09-07-2024, 05:50 AM
    • C152Heavy
      Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
      by C152Heavy
      Summary for TL-DR readers:
      • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
      • Have obtained Samsung schematic & service documents - Can upload if helpful.
      • Have read ALL applicable threads
      • C1818 and CP820 replaced as low hanging fruit
      • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
      • VCC pin (18) of PFC...
      01-11-2023, 02:53 PM
    • sansanpartida
      Samsung QE82Q70RAT no backlight
      by sansanpartida
      Hi everyone!
      Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
      My issue: No backlight.
      Model: QE82Q70RAT
      Type No: QE82Q70RAT
      The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
      So hopefully, I can fix this cheaper.
      05-22-2024, 06:56 AM
    • howardc64
      Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
      by howardc64
      TV was fixed just after removing Samsung's rear snap cover.
      This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
      Maybe PSU->backlight connector didn't have a good contact?...
      07-23-2025, 12:34 AM
    • howardc64
      Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
      by howardc64
      • Prior owner tried a replacement main board. No difference.
      • Samsung 2x red blinking standby LED = panel fault
      • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
      • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
      • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
      07-19-2025, 10:54 PM
