ccfl problem
  • chetreynolds
    chet
    • Aug 2010
    • 77
    ccfl problem
    I have a 20 inch monitor that has a bad bottom ccfl which shuts the inverter down . It is not worth the cost and time to replace the lamp . Has anyone tried to subsitute a resistor for the lamp to prevent the invertor from shuting down . The remaing 3 lamps should make it uasble .
  • retiredcaps
    • Apr 2010
    • 9271
    Re: ccfl problem
    Using a resistor to fake a Inverter into thinking a CCFL is good
    https://www.badcaps.net/forum/showth...=resistor+fool
    --- begin sig file ---
    --- end sig file ---
    • mikey5791
      Help on Samsung Syncmaster T220 dead ccfl lamp
      by mikey5791
      This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
      Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
      10-18-2020, 03:17 AM
    • ttmi100x
      HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
      by ttmi100x
      Greetings everyone,
      I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
      The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
      Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
      Upon closer inspection...
      07-31-2024, 06:36 PM
    • theone111
      by theone111
      3. Problem: TV shuts down
      07-22-2024, 10:36 AM
    • Zeonalbasta
      Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
      by Zeonalbasta
      i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
      The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
      09-13-2024, 01:17 PM
    • Gibon378
      Problem with stopping audio and video for no reason
      by Gibon378
      PC Specs:
      • CPU: Ryzen 5 1600
      • GPU: GTX 1080 Palit JetStream
      • MOBO: ASRock ab350 PRO4
      • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
      • PSU: XFX 650W (don't remember what model)
      • OS SSD: ADATA SP920
      • OS: Windows 10 21H2
      Problem description:
      Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
      11-19-2022, 09:41 AM
