Acer flashing Red/Green/Blue
+ More Options
Posts
  • 11flint
    • May 2010
    • 24
    Changed the controller board on this monitor, and all I'm getting is flashing full screen red green blue white!
    Help!!!
    Heaven, is a place where all IC's are DIP.
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: Acer flashing Red/Green/Blue
    test mode?
    my old 18" HP L1820 (Acer OEM) does that if there's no signal..
    • 11flint
      • May 2010
      • 24
      So is my scaler ic screwed? Love your quote btw Scenic, ha! I'm half German. Mom's from Frankfurt. You guys have more hope then we do mate.
      • Scenic
        o.O
        • Sep 2007
        • 2642
        uhm.. put a signal to it and see what it does.
        older monitors used to show those color patterns if there was no signal (instead of showing a "no signal" box floating around on the screen)
        • 11flint
          • May 2010
          • 24
          That did the trick. Cheers man
          • Scenic
            o.O
            • Sep 2007
            • 2642
            np
            • 11flint
              • May 2010
              • 24
              Ok, I'm happy as a pig in **** that the monitor is up and running, but at the end of the day, is it normal for the monitor to go into what I can only describe as "test mode" both when on w/o signal and when it should in fact be sleeping?
              My guess is that this is a firmware issue. Could anyone tell me how to flash this (Acer AL1716) monitor? Sorry in advance if there's already a sticky on this topic.
              Many thanks!!!
              Oh, and scenic....prost!
              • 11flint
                • May 2010
                • 24
                For the sake of closure, this problem (miracolously) rectified itself. Left the monitor unplugged for several days, when I hooked it up again, no more red/green/blue, and monitor goes to standby (amber lED) as intended.
                • gerg
                  • Nov 2010
                  • 278
                  What model acer is it I have about 1000 of these monitors in the field I might be able to tell you from experience if it might have bad caps
