Chimei CMV 946A caps
  • alexanna
    • Mar 2010
    • 1346
    #41
    Re: Chimei CMV 946A caps
    Well for what it's worth.
    I have had monitors, that after a re-cap I have noticed flickering on the screen for a while after initial power up.
    After the monitor has run long enough to get good burn in, the flickering has gone away.
    • NobbyJones
      • Aug 2011
      • 12
      #42
      Oh ok thats interesting to know! i'll keep my eye on it then. Thanks
        by momaka
        03-12-2025, 03:42 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
      • Foetuss
        Gigabyte GA-6OXT :: caps question
        by Foetuss
        Good evening
        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
        But I was also suprised about the bigger boys, which are 330µF 25V.
        Could it be they used 25V caps because they were cheaper / available at that time?...
        02-11-2025, 12:22 PM
