Hannspree M19W1 2 secs on Prob
  • ceedy
    • Nov 2008
    • 76
    Re: Hannspree M19W1 2 secs on Prob
    Many Thanks to you all for the help..
    24 hrs and still going strong .. so hopefully its sorted ?
    take care all
    Chris
    • Chivo77
      DELL LATITUDE 5420, ST 20TFKN3, LA-K491P REV:2.0 (A01) powers on and die about 15 secs later, no video
      by Chivo77
      hello friends, I have a DELL LATITUDE 5420---MODEL P137G, ST 20TFKN3 LA-K491P REV:2.0 (A01) and its quite a challenge. It powers on with the battery disconnected, lasts on for about 15 secs, and then shuts off. It does the same with battery only (no adapter). With battery and adapter it sometimes starts after hitting the button several times. It displays nothing in every case. Since only the Boardview is available, I guided myself with schematics similar to this laptop (I'll add them down).Some measurements:
      1- After receiving power SIO_SLP_S0# goes high and never changes.
      2-every...
      07-03-2025, 09:20 AM
    • paparazzo79
      Hannspree HT 273 HPB USB cable type A to type B?
      by paparazzo79
      Hi guys.
      I purchased the monitor from the link below:
      https://www.hannspree.eu/product/ht-273-hpb/
      Since I will be using monitor from bed, I'd need longer usB type A to type B plug cable.
      I got one which is 4.5m long, regular one
      May I use it without harm to the monitor?
      I suppose cable which came with monitor is regular type A to type B,not some speical cable.
      I could picture what is labeled on the cable, if it matters for assistance.
      08-12-2023, 05:28 AM
    • Shobos
      Dell E6420 XFR Rugged starts to boot but after 3 secs shuts down.
      by Shobos
      Hi, I bought 6420 XFR that tries to boot but shuts down after about 3 seconds, CPU gets warm, fan starts.
      So far I have tested all rails wich are good, BIOS flashed with CH341, 3.3,5, main rail present. multiple ram sticks tested. Sometimes it might stay on for longer like 4-5 seconds but not always, theres no picture whatsoever. Also on some rare occasions the caps lock flashes 1 time by itself.
      NOTE: I am using bench power supply not dell charger with ID pin and NO battery present, kinda doubtful this would cause this issue.
      Any help is welcome. Thanks !
      07-29-2025, 03:53 PM
    • dikei
      China Make TV with LG Display horizontal line at top and video freezes 1-3 secs
      by dikei
      Hi guys!
      I'm new to TV repair and just started looking into troubleshooting guides and other online info.
      Right now I have a Chinese make with LG display that is faulty. If I am not wrong I see two different problems here below.
      1. There is a line(white/multicolored) at the very top of the display that shows thinner sometimes and slightly thicker in some occasions.
      2. For any video the play freezes 1-3 secs and at the same time brightness goes low and returns to high when video continue to play.
      From my initial research...
      07-06-2023, 11:53 AM
    • Victor Moreira Silva
      Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
      by Victor Moreira Silva
      I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
      Well, my decice specs are the following:
      Model: Acer Nitro 5 AN517-54-55T5
      CPU: Intel Core i5-11400H
      GPU: NVIDIA GeForce GTX 1650
      Motherboard: GH51G LA-L181P Rev:1c
      The symptom:
      When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
      05-26-2025, 10:49 AM
