Lost chip resistor, need help with value
  • hill8570
    • 6
    Hey, all! Noob here, with a weird request...
    I was recapping a TDK XAD819AR power supply out of a Hanns-G HC194D LCD monitor when I managed to knock loose and lose a little chip resistor in the middle of the back of the board -- looks like resistor R18. I figure I should be able to hack in a small 1/8W resistor in place of the chippy if I knew roughly what value it was, but I haven't been able to track down a service manual or schematic for that board, and haven't even been able to find an app note for the little SMD-8 SC6841SZ MOSFET driver that the chippy was next to.
    Does anyone happen to have a schematic for that board, or maybe one of those boards out on the bench so you could check to see the value of the chip resistor? I'd let you have my firstborn male child, but he's a pretty obnoxious teenager, so you'll have to settle for my eternal gratitude.
  • mockingbird
    • Dec 2008
    • 5484
    Re: Lost chip resistor, need help with value
    I have this board.
    XAD819AR
    EA02819x
    R18 says "10R0" on it if that means anything to you.
    Now if you could help me out, I don't know which capacitors to get for this board, I took them all out when I tried to repair it and failed. Would you be able to tell me what caps it has?
    All I got was a white screen after I changed the caps.
    • hill8570
      • 6
      10 ohms...cool -- that'll be easy :-)
      Value-wise, my board had:
      2 - 10V 1000uF
      2 - 25V 470uF
      2 - 25V 220uF
      2 - 25V 100uF
      1 - 10V 100uF
      1 - 50V 47uF
      1 - 50V 4.7uF
      A lot of the CapXon-branded capacitors were bulging, but just to be on the safe side I changed out all of the little electrolytics, CapXon or no.
      There was also a big ol' 100uF 400V filter cap over near where the line voltage came in...that guy looked OK, so I didn't mess with it.
      • mockingbird
        • Dec 2008
        • 5484
        • mockingbird
          • Dec 2008
          • 5484
          Can you give me also the locations? Also, what are the locations and values on the logic board. Series is also important if you don't mind
          I know it's asking a lot.
          Yea, the 400v 100uF Taicon is still there. I am gonna change it too when I get working on it again, because I haven't had good luck with Taicon primaries. Has been sitting here for months.
          • hill8570
            • 6
            Here's the power supply...assuming it uploads OK. Might not get the logic board posted until tomorrow...getting to be beddy-bye time. Not sure what you mean by "series".
            • mockingbird
              • Dec 2008
              • 5484
              By series, I mean, on the capacitors, it should say something like "KF" or "GF" or something like that.
              • mockingbird
                • Dec 2008
                • 5484
                Also, here is the same photo with better clarity. Can you tell me if I read your photo correctly?
                • hill8570
                  • 6
                  You've got good eyes. Yes, those are the correct values.
                  Other than the Taicon, all the capacitors I have in there now are Panasonic FM series. If you need to know the manufacturer & series of the originals, let me know -- I probably haven't emptied that trash can yet.
                  • hill8570
                    • 6
                    Here is the logic board. Hopefully this pic is better than my first attempt.
                    • mockingbird
                      • Dec 2008
                      • 5484
                      Thank you very much, the picture is a lot clearer.
                      Our logic boards are very similar, the physical dimensions, connector positions, etc... But they are slightly different.
                      Yours is:
                      DAL9ZCMB124 Revision B
                      Mine is:
                      DAL9TAMB1A1
                      Unfortunately the cap layout is different on mine. I'll see if I can get one like yours somewhere, maybe it will also solve my problem.
                      Let us know how the recap goes.
                      • hill8570
                        • 6
                        The recap went fine...the 10ohm resistor I hacked in was one of my uglier pieces of rework, but it's getting the job done. The monitor is back in service, and now working perfectly.
                        BTW, I checked the trash, and the majority of the original caps on the power supply (including all of the bulging ones) were CapXon GF series. A couple (the 47uf and the 4.7uf) were TL CD81 series.
                        Thanks for all your help!
                        • mockingbird
                          • Dec 2008
                          • 5484
                          No, thank you!
                          This is very helpful. I will check GF spec to see if FM is an exact replacement. But hey, it's working, so the proof is in the pudding.
                          • acedogblast
                            by acedogblast
                            11-02-2024, 05:13 PM
                          • DynaxSC
                            ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                            by DynaxSC
                            Hi
                            I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                            Today, 12:20 PM
                            by SMDFlea
                            Bad...
                            09-02-2021, 04:40 PM
                          • Troystain
                            Help EZP2023+ updated chip database for w25q256jveq?
                            by Troystain
                            Hello, anyone here have updated ezp2023+ chip database in .dat file format.
                            I need to add w25q256jveq chip but I do not know what data should I type.
                            I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
                            The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
                            11-25-2024, 12:53 AM
                          • baletak
                            Lenovo T490 - motherboard serial - windows licence lost - after corrupt bios chip replacement
                            by baletak
                            had T490 with faulty bios chip. Bought chip out of ebay and soldered on. Laptop starts and works however serial numbers of laptop and motherboard do not match.
                            I have updated laptop model number.
                            1) I did not find the way to update laptop serial number - I have this one.
                            2) I dont know where to get my motherboard serial number and how to update it. Is it somewhere physically on the mainboard? How do I update it?
                            Hope to find someone to help me with this as I am hitting dead end at the moment.
                            Many thanks
                            Miro
                            05-23-2025, 01:21 AM
