Re: Hanns-G HG281D 28" TFT - Multiple Problems
The one which has the plug connection on it or leads to the plug.
I've got the back off and the metal box with the electronics,.
there's two PCB's is it the large on I need to look at?Leave a comment:
Sorry, I misunderstood, I'll give that a go nowLeave a comment:
I can afford the capacitors, it's just a new monitor that would be a problem but thank you very much.
Could you advise me of which caps I need to order, I don't have a clue which ones need replacing either but I guess I can tell when I have the new ones as I guess they will be very similar to the ones on the pcb.Leave a comment:
I expect another week or maybe a month out of your monitor if you're lucky.
Open your monitor up. If you are strapped for cash let me know what caps you need and I'll add them to a Farnell order I'm making, they are 50p or so each.Leave a comment:
Thanks, I'll do that
Also i forgot to ask, what caps should I get and how many are there, I can't find it mentioned in the thread?Leave a comment:
Changing caps is pretty easy, just do them one at a time and make sure you get the polarity right. Also look up basic soldering techniques.Leave a comment:
I understand, what if I leave it on and just let it power down when I turn off the computer, will it last any longer?
Also how difficult is it to change the capacitors, I could possibly borrow a soldering iron and there is a Maplin store close where I could get them.
At least it's working now, any more use is a bonus until I get some spare cash in.Leave a comment:
The fix will not be permanent! You will need to replace the capacitors soon, as you will only get maybe a month or so out of it with this technique.Leave a comment:
I registered to say a huge thank you to everyone in this thread but to Mikeley in particular.
I had the problem where I couldn't restart my Hanns-G and was convinced that it was gone for good but decided to look on the internet just in case and came across this thread.
As I haven't got the skill or equipment to fix the capacitors mentioned I was relieved to see Mikeley's suggestion of warming them. Nervous about opening the case I removed the stand and rested the monitor against the radiator and after about a half hour, to my delight, it came back on.
So thank you so much for the advice, you have saved me buying a new monitor which at this time I could barely afford.
Kind regards,
Neil.Leave a comment:
It could be a number of problems causing this - as you say caps could be one and it could be the power supply the main board or both. It could also be the voltage regulators.
First thing perhaps would be to remove and reseat any connectors especially if their is a flat one to the panel which might need a clean.
Have you tried a different hdmi cable..
Have you tried it with a different pc.
As it says these run on the hot side so even if caps have no visible damage they could
still be dried out. As it is a 28 inch screen has to be worth investing in good new
caps. Start with the power supply and if no improvement test the voltage regulators
then re cap the main board. If you didnt want to do all the caps on the main board I would start with the ones near to the voltage regulator.
Regards, Bart.Leave a comment:
then re cap the main board. If you didnt want to do all the caps on the main board I would start with the ones near to the voltage regulator.Leave a comment:
I have read all comments with much interest. Thank you for sharing.
I am facing the same problem as many of you. When I connect the HDMI cable between my laptop and HG281D screen I get screen blanks (with VGA no screen blanks, but some flickering especially with white backgrounds). After a while the blanks disappear and everything appears to be working just fine. Every time I close down and restart, I get the same issue. From the comments on the forum I concluded that it is the logic board (although I am not sure, could also be the power supply). I checked the capacitors visually to see if any of them is bulging out. This appears not to be the case. My question is now: Which capacitor(s) do I have to replace to get my screen not to blank at startup and after?
Thanks a lot in advance.
Good luck slowcorrado!!Leave a comment:
I would wish you luck... but based on the last PM I received from you, you've already had 100% luck and have fully repaired your HG281D! Very nice!! Congratz!
Glad to have been of help,
SKLast edited by stevekasian; 07-08-2011, 05:22 AM.Leave a comment:
New user here. Just wanted to thank everyone for their excellent advice. I recapped my power supply and now have a "more working" monitor. :-) I still have lots of screen noise and it will sometimes go dark, so it looks like I'll need to recap the logic board. Wish me luck!Leave a comment:
just found this forum with the aid of google
Had problems for a few months with my HG281D
Like Teddyv (post #73)
"I also starts up when I turn it on and takes a while for the image to show up, Although the image shows up well it starts to flicker from the bottom part of the monitor and then vertical lines appear to shimmer and dissapear". although mine seems to shimmer constantly and flicks on and off all day lol
Not had the case open yet as i am trying (without hope of success) to get HannsG to cover it under the warranty and it seems no shop in Reykjavik will touch it. Some great advice on the thread and i will use this info to aid seeking a genius to actually do the fixing.Leave a comment:
I would like to thank all of the contributors in this thread. I am a new member and I know that there are thousands out there suffering with the Hanns G. I have been repairing electronics most of my life and hope to contribute here in this forum. Looks like it's time to go pick up some new caps and get to work.Leave a comment:
Then today it randomly sprung to life like a zombie but shortly died thereafter. I have no idea why it would have done that and its the first time I've seen it running. I discharged capacitors on the board last night, then it was sitting today.... -
by fharris1977Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.1 Photo
by npielawskiI will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...Yesterday, 01:53 AM -
by CrystaleyesHi all.
I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
by fuxxyUN55D6000 I've posted about before.
Initially had bad backlights, of which both entire strips were replaced.
Then TV started not staying off. Every poweroff command was recognized, TV would power off then power right back on, even with nothing attached.
Now, no output at all. No red Power LED, No response to remote. No clicking or coil whine.
From other threads, tested various outputs on the PSU. Noticed that when the mainboard was unplugged, the backlights would turn on.
Backlight Connector CNL802:
Logic board unplugged:
pin... - Loading...
