need help on a laptop LCD panel, "2 minutes to black"
  • meanderer
    • Jul 2010
    • 50
    I am trying to repair a acer laptop with a dark panel. The panel first came as completely dark. I first suspect the inverter. Ordered one online and replaced it.
    It lights up for about 5 minutes thru the windows boot screen. Then shuts off again. The inverter replacement improves the problem but doesn't fix it.
    I tried to turn down the brightness a bit, the light starts to flicker then shuts off as well.
    Should I try a different inverter? or should I try to replace the bulb, which is something I have little confidence in doing (and probably give up at that point)?
    Another laptop in the past, I was able to keep the light up by lowering the brightness. I cannot do the same with this one. Is there any difference between the 2 cases?
  • BShanahan14rulz
    • Aug 2010
    • 20
    Re: need help on a laptop LCD panel, "2 minutes to black"
    I just want to add that replacing the bulb is probably easier than you are thinking.
    I usually don't take the screens apart unless I'm harvesting some diffusion plastic or diffraction gratings, but of the two screens I have taken apart, the tubes are in a metal "reflector" thing, and the whole thing slides out one side of the backlight panel.
    So if the experts here reply that you may need new tubes, don't chalk it up as a loss just yet. I'm not an expert, but it does sound like as something heats up, it fails or goes out of spec. New inverter board probably rules out a bad inverter board. If the laptop is pretty old, the tubes may be bad.
    I've got a travelmate 42-something-or-other, that thing's got a huge screen but very dim. Quite honestly, I'm surprised that the tubes haven't shattered, the way I treat that poor thing!
    • alexanna
      • Mar 2010
      • 1346
      Well you have replaced the inverter, so I would hope it's good.
      On the low voltage side of the inverter.
      Check if you have a power and a ground going to the inverter, and what are the voltages of the BL on signal, And the ADJ dim voltage, When the back light is on. Do any of these voltages change when the back light goes off? You are trying to identify 3 pins with a voltage and one pin that has a ground.
      This should give you an idea of what to look for http://www.lcdparts.net/howto/U_PIN.aspx
      Al
      • meanderer
        • Jul 2010
        • 50
        thanks for the help, turns out that these so called "new" inverters are not made to spec and turns off after 2 minutes. I ordered one USED and it works perfectly fine for at least 2 hours...
        Since I have been ordering inverters from the same vendor. This vendor's bad inverter record is currently 100%.
        and also the chance of a used inverter to work is at 100% as well.
        What should I get in the same situation I wonder :P
          Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
          This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
          09-06-2024, 09:30 PM
          Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
          This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
          09-06-2024, 08:47 AM
        • RdeveLabs
          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
          by RdeveLabs
          To all the members here...
          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
          05-05-2025, 04:59 AM
          Microsoft Surface Laptop Surface Laptop Go 2 Notebook Go 2 Specification for Upgrade or Repair
          This specification for the Microsoft Surface Laptop Surface Laptop Go 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop Go 2 boardview and Surface Laptop Go 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
          09-07-2024, 06:11 AM
          Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
          This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
