ive got a viewsonic lcd 19" with speaker, when suddenly it start blinking, the power light and the display itself.. i have already checked all the caps and it seems that all caps are in good.. i hope you can help me...
viewsonic lcd blinking
Re: viewsonic lcd blinking
And since you didn't bother to include pictureswe can't really look for other problems, can we?
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by eryjusHello,
by Paxman_SwedeHello!
I have studied the board and...-
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
by FoetussGood evening
I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
But I was also suprised about the bigger boys, which are 330µF 25V.
Could it be they used 25V caps because they were cheaper / available at that time?...-
- Loading...
