Planar PL1700-BK - backlights go out
Re: Planar PL1700-BK - backlights go out
Additionally, you may not need new ccfls. It could be the ccfl wiring that is at fault.--- begin sig file ---
--- end sig file ---Comment
I looked at that datasheet, I can't even fit that in my mouth let onlone digest it. I was just looking for ccfl's, but it's a topploy panel they look hard to find.Comment
So plug the "working" middle ccfl into the far left. Then try the "working" middle ccfl into the far right.
Report the results.--- begin sig file ---
Taking the middle lights and pluging them into the outer sockets, the left(J903) one came on really dim and then shut off and the right(J906) one didn't come on at all. I plugged the outer lights into the inner sockets and they came on bright and then shut off. So when the either light is plugged into the inner sockets(good ones I hope) they all come on bright and then shut off.
I didn't know you could switch the lights around like that(add that to my troubleshooting notebook).Last edited by De3rcr; 11-30-2010, 06:12 PM.Comment
Okay, just going forward and to make it easier to trace and follow, the far right is which J connector? J903, J904, J905 or J906?--- begin sig file ---
And just to confirm, all the ccfls light up (when switched around) except when plugged into the "far right" connector?--- begin sig file ---
The good news is that J905 is working so we have a known good circuit for comparison.Last edited by retiredcaps; 11-30-2010, 06:30 PM.--- begin sig file ---
OK,
If you plug in the 3 other ccfls one at a time to the connector J906 that does not light the ccfl,
Do you still get no light, or do any of the other bulbs light up dimly?
Al.Whatever I do, I consider it a success, if in the end I am breathing, seeing, feeling and hearing!Comment
I also resoldered J906 and J903 same resultsComment
36 Monitors, 3 TVs, 4 Laptops, 1 motherboard, 1 Printer, 1 iMac, 2 hard drive docks and one IP Phone repaired so far....Comment
This inverter transformer uses a newer design. Early designs had one CCFL per transformer. One end of the secondary fed the CCFL, usually through a capacitor. The other end of the secondary was either tied to ground or to a current sensing circuit. Later designs coupled the output to two CCFLs by using two capacitors.
This design uses two CCFLs driven from opposite ends of the secondary windings. The return lines from the CCFLs either go to current sensing circuitry or to ground. There are usually a few capacitors to sense voltage, and to tune the circuit.
The best way I can illustrate the difference is the old way was like two flashlight batteries, each with a flashlight bulb connected to the top and bottom. In that design, each battery and bulb set is independent of the other.
The analogy for the newer design would be two batteries in series, and two light bulbs in series. and the light bulbs connected from the bottom of one battery to the top of the other. In this case, they are dependent on the other.
This means that disconnecting one bulb of the pair is not a valid test UNLESS some provision is made to pass current through the open socket. The best way would be to use a resistor. Radio Shack 271-1131 is a 5-pack of 100K ohm .5 watt resistors. They should work FOR A SHORT PERIOD, and are normally stocked in the stores.
This is going to be crude, but what I would suggest is soldering one resistor across each unused socket (I've circled the pins of each socket in matching colors.), then plugging a CCFL into one socket, turning on the monitor briefly and evaluating how bright the CCFL lights. For the first test, I would suggest trying all four CCFLs in turn in the same socket. For the second test, I would suggest testing one CCFL at a time in each socket, with the other sockets jumpered by a resistor. Yes, this will require unsoldering and resoldering resistors. Be careful, the resistors may get hot.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
PlainBillComment
I'd say little chance of blowing the board. The Radio Shack resistors are underrated for this, they will get warm.
What I'm hoping is you will find one of the two sides will be noticeably dimmer for all CCFLs (bad transformer), OR one CCFL will be noticeably different (bad CCFL or wiring).
I'd say 5 seconds or less. You want to be able to say 'Bright', 'Dim', or 'none'. You still might get 'two seconds to black', the resistances are a little low (120K ohm would be better).
PlainBill, going to replace that and try again.
I don't know why it didn't click before, but the LG Flatron 1718S-BN that you repaired can be used as "good" ccfl.
You don't take out the ccfls in the LG. Just drag the LG LCD close enough to the Planar and stretch out the connector (don't let the two LCDs touch).--- begin sig file ---
PlainBill
Then I saw this(I didn't think about this either DUH!!)
and took apart the LG and hooked it up and the ccfl's shut off after about 5 secs. Transformer???Comment
If you haven't already try re soldering the inverter coil and anything else that's thru hole around J906
by nick3092I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
Channel: General Capacitor Questions & Issues
by bpcannan'Morning,
I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate... -
by chth96I want to calculate capacitor ESR referring to below guide.
https://forum.digikey.com/t/calculat...-from-tan/2633
I must find out dissipation factor(Tan(δ)) for nichicon lxj series(6.3v 1500uf,25v 1000uf ,10v 2200uf)
I finally found out datasheet which has all series of nichicon capacitor.But unfortunately, It removed old nichicon capacitor.
Is there anyone who still has old nichicon datasheet which has information of LXJ series?-
by MUNASHEHi everyone
I have an Ecco LH32 Led tv with no backlights. PSU is reading 7.6 v, using two led strips of 6 leds each, I have no backlights tester.
Does anyone know the backlights voltage for this model. Also want to ask if backlights leds come in a parallel arrangement, or series only
Pliz help -
I have this TV that turns on and shows a pic but there is a line of backlights out.
So I opened it up tests the backlights. Found the 2 leds that are a fault. However these leds measure 20.2v per led. The 2 bad leds work but only measured 9v.
I've never seen leds like this on a tv that measure that high. These are super tiny (I'm guessing that where the nano part of the name comes from.
I planned to replace just the 2 bad leds but never seen a 20v led.
Anyone else have experience with these tv backlights?... - Loading...
