ViewSonic VG1930WM
  • Diablo_Rojo
    • 28
    ViewSonic VG1930WM
    I am trying to res-erect a ViewSonic VG1930WM which shows no signs of life(no LED, no anything). I see no bulging caps. I have verified 14.7v and 5.19v from the power supply. I have attached a page from the LG L192WS manual which apparently uses the same control board(ILIF-020) as the ViewSonic. Pardon my sloppy notes on the schematic. My thoughts are that the voltage regulator U102 is bad. It is an AS1117L-18. I appreciate any input.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: ViewSonic VG1930WM
    U101 should also be outputting 3.3V DC. You can test both U101 and U102 to see if they are shorted. Any resistance reading less than 30 ohms between the pins 1-2, 2-3, and 1-3 suggests a short.
    --- begin sig file ---
    --- end sig file ---
    • alexanna
      • Mar 2010
      • 1346
      So the vin is pin #3 and it has 1.26von it,Is there away you could lift that leg off the pad and see if you read closer to the 5v.?
      Al.
      • Diablo_Rojo
        • 28
        Thank you for the response. I measured U101 and 102 in circuit. The lowest reading I got was about 400 ohms between pins 1-2 on U102.
        • Diablo_Rojo
          • 28
          Thanks for the idea. I have lifted the leg off the pad for pin 3 on U102. I still get 1.26v on the pad and 4.89v on pin 3 of U101. Maybe C101 is shorting out?
          • alexanna
            • Mar 2010
            • 1346
            I missed the part where you are only reading 1.26v on the output of U101.
            Something is taking the voltage low .Is anything hot to the touch
            Al.
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              Do you get anything at all in this monitor to show life? Pwr led? 2sec to black?
              • alexanna
                • Mar 2010
                • 1346
                Well if he has lost the 3.3v and the 1.8v regulators ,I doubt it
                Al.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  My schematic reading skills is presently F-, but I suggest replacing U101 first to see if you get 3.3V DC on VOUT. I can't tell if U102 VIN should be 4.89V DC or the output voltage of U101 VOUT (since the output of U101 VOUT = U102 VIN)? Did I mention my schematic reading skills is F-?
                  I have a monitor right now with 2 shorted out voltage regulators on the logic card. So it isn't impossible that you have 2 bad voltage regulators? I realize yours are not shorted, but since U101 is outputting low voltage it is bad.
                  From what I understand of reading PlainBill's posts, a voltage regulator failing low is better than failing high and destroying other components with too much voltage.
                  • PlainBill
                    • Feb 2009
                    • 7034
                    There are two problems here. First, the schematic is wrong (or you made a mistake measuring voltages). The schematic shows both U101 and U102 getting power from the 5V supply. That is an unusual arrangement. Given other flaws in the schematic, I suspect it is wrong.
                    By the voltage measurements, U102 gets it's power from the output of U101. That is a common arrangement.
                    Either U101 is bad, or something is overloading the output. U102 appears to be good. One trick you can try is to apply 3.3V to the output of U101. If it comes up to 3.3V, the regulator is definitely bad. If it does not rise, something is overloading the 3.3V power rail.
                    You probably don't have a spare 3.3V power supply sitting around. Use two 'D' cells (flashlight batteries) in series. Fresh alkaline cells will provide about 1.6 volts each.
                    PlainBill
                    • Diablo_Rojo
                      • 28
                      Thanks for all the input. I never thought about the schematic being incorrect but it makes perfect sense when I see the input voltage of U102 is the same as U101 output. I was only able to get up to 3.1v with the batteries I have on hand(4 C's in a parallel series combo). When I apply the 3.1v to the output of U101 the voltage falls to 2.6v. Keep in mind that this test was performed with the input leg of U102 still lifted from the pad and the power on. Any advice from here is greatly appreciated.
                      • PlainBill
                        • Feb 2009
                        • 7034
                        Off the top of my head, the batteries should be able to source over 1 amp in current. Look up the specs of U101. If it's rated for more than 1 amp, U101 is probably bad. Look (CAREFULLY!!!) for an IC getting hot.
                        PlainBill
                        • Diablo_Rojo
                          • 28
                          Just wanted to update and give thanks to everybody and especially PlainBill. The VG1930WM is back in service!! I replaced U101 (the AS1117L-33 regulator) and the old girl reciprocated with a blue led then a full screen picture. No problems after several hours. Thanks again.
                          • lostone
                            Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                            by lostone
                            Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                            First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                            When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                            05-19-2024, 11:40 AM
                          • StefanNg
                            Viewsonic VX2718-PC-mhd SG2701B01-8
                            by StefanNg
                            Hi, Badcaps.
                            I am troubleshooting a monitor
                            Viewsonic VX2718-PC-mhd.
                            Panel model SG2701BSG2701-8
                            Symptoms is no image.
                            This panel has 2 panel board connected by a U-ribbon.
                            When I disconnected the ribbon, I get a perfect half screen image.
                            I took some test point voltage, when ribbon disconnected.
                            HVAA 8.38v
                            FVDD12 1.21v
                            FDD33 3.3v
                            VIN 11.79v
                            VAA 16.85v
                            VGHF 30.16v
                            VGL -8.02v
                            CK1_I ~ CK8_I 1.403v
                            CK1_L ~ CK8_L 8.26v
                            When I connect both panel board
                            HVAA, VGHF, and CKx_L...
                            05-17-2025, 01:43 AM
                          • Fagauthier
                            Viewsonic power supply model #EADP-64BF B Need circuit diagram…
                            by Fagauthier
                            I have à defective Viewsonic monitor. I can't find a circuit diagram for it' power supply.
                            Model #EADP-64BF B
                            The user manual have all diagram except for the power supply. I would appreciate help to find the circuit diagram, thanks...
                            07-08-2023, 08:02 PM
                          • Returning Buick
                            Viewsonic G810 vertical deflection problem
                            by Returning Buick
                            I have a G810 monitor i've had for years but it has developed a problem with vertical collapse. Is there anybody here who has worked on these and can help me find where the circuit even is for the vertical deflection?
                            04-01-2025, 07:57 PM
                          • RetroComputingGrotto
                            Viewsonic VA2010wb (High Pitch Squeal At Power On)
                            by RetroComputingGrotto
                            I've got a monitor on my workbench at the moment that makes a high pitch squeal (that I cant hear as my ears are too old) when you power it on and lasts a couple of seconds before quitening and apparently it can be heard at regular intervals whilst on.
                            On opening up the monitor and looking at the PCB the usual suspects showed their heads so I have already replaced all the electrolytic capacitors.
                            The other issue that was reported with this monitor was the fact it took ages to start displaying anything after pressing the power button.
                            What component(s)...
                            02-03-2025, 06:00 AM
