Hannspree HF237HPB
  • csquires
    • Nov 2010
    • 11
    Hannspree HF237HPB
    Hello all, I've read a lot of the forums regarding 2 seconds to black (including billy66's excellent guide), and I've tried as much of the troubleshooting as my extreme noobness will allow. I have a Hannspree HF237HPB. All was well until a few weeks ago, when it starting turning off within a few seconds of being turned on, while the power light in the corner stayed blue. It didn't do it all of the time, if the monitor has been turned off for a few minutes, it would start up fine, and stay on. If I turned on the computer and the monitor went 2 secs to black, i would just turn the monitor off and wait a few, and it would usually stay on after i tried again. That worked less and less frequently until it would never stay on more than 2 seconds. I can see the screen with a flashlight pointed at it. I have zero electronics know how, i didn't own a multimeter or a soldering iron before this, but i am a DIY kinda guy, so i googled it, and ended up here. From what I've read here, definitely sounds like an issue on the inverter board. I can't see any obvious damage, the caps appear fine, no bulging, no leaking, etc. I also don't see any discoloration around any of the components. Flipping it over, the i don't see anything obvious here either. Maybe someone notices something that might escape a mere noob such as myself? Any idea what the most likely culprit is? If it's relevant, I also noticed that I often got two secs to black whenever my resolution changed, like when loading a game, etc. Pics are attached, thanks to all in advance!
  • PlainBill
    • Feb 2009
    • 7034
    Re: Hannspree HF237HPB
    I notice a couple of things. first of all, you deserve a better camera. I agree, there are no signs of bulging caps, but that's no proof that they are all good.
    In the 1st picture, about 7:00 o'clock there are a couple of caps with green sleeves. What brand are they?
    PlainBill
    • retiredcaps
      • Apr 2010
      • 9271
      You have the sunlight and decent focus. Put your camera in macro mode and you will get clear focused pics.
      What parts of the guide did you already try? It was written with newbies in mind in addition to people with some electronics knowledge.
      --- begin sig file ---
      --- end sig file ---
      • csquires
        • Nov 2010
        • 11
        I mostly understood the guide, but i guess my lack of electronics knowledge was a little limiting. I tested the fuse on the board successfully, appears to be fine, but can all the other components be tested in circuit? Is there any way to test the caps with just a multimeter, or does that require the ESR tester? Is my best bet just to start by replacing all the caps, regardless of appearance? Could i fit any more question marks into this post?
        PlainBill, the greensleeved caps are Samxon, which appear to have a mixed following on this forum.
        Also, any substitute for a desoldering pump or braid? i have not yet purchased any desoldering stuff and will likely have to wait a week or so to do so.
        were the pics at least adequate or should i retake with a borrowed camera? (no macro setting on mine) thanks for the prompt responses!
        • retiredcaps
          • Apr 2010
          • 9271
          If you re-read posts #13 and #14 of the guide, all your questions are answered.
          • joecnc2006
            • Jan 2011
            Did you find a cause, I have the exact Monitor/Board with same problem.
            Thanks,
            Joe
            • johnh35
              • Aug 2013
              • usa
              Ok, I am getting ready to replace the caps on mine, but how in the heck does the back come off?
              • peter99
                HP 245 laptop not charging when turned on
                by peter99
                helo everry body!!!
                My laptop HP 245 AMD 14-FP5-6L -GDDR5X2 has a battery charging circuit error:
                - If not power on, battery charge ok.
                - if i turn on the power, not charging the battery ( the battery charging indicator light, from yellow to white)
                The laptop only charges when not turned on. I have changed the battery and charger, but the situation remains unchanged.
                I replaced the BQ 25A charging IC but the device only charges when not turned on.
                everyone please help me with solution, what should i do ?
                thanks a lot !!!!!...
                04-04-2025, 07:35 AM
              • reessi
                Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                by reessi
                Hello:
                I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                I started on the ACER:
                Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                10-29-2024, 11:31 AM
              • Chivo77
                DELL LATITUDE 5420, ST 20TFKN3, LA-K491P REV:2.0 (A01) powers on and die about 15 secs later, no video
                by Chivo77
                hello friends, I have a DELL LATITUDE 5420---MODEL P137G, ST 20TFKN3 LA-K491P REV:2.0 (A01) and its quite a challenge. It powers on with the battery disconnected, lasts on for about 15 secs, and then shuts off. It does the same with battery only (no adapter). With battery and adapter it sometimes starts after hitting the button several times. It displays nothing in every case. Since only the Boardview is available, I guided myself with schematics similar to this laptop (I'll add them down).Some measurements:
                1- After receiving power SIO_SLP_S0# goes high and never changes.
                2-every...
                07-03-2025, 09:20 AM
              • bykanovm
                Thinkpad W541 Works from the mains and charges the battery only when it is turned off
                by bykanovm
                Lenovo Thinkpad W541 Wistron LKM-1 WS MB 12291-2 Works from the network and charges the battery only when it is turned off.
                If you press the power button, the laptop turns on and works from the battery, but does not take power from the power supply.
                If you boot into Windows and close the lid while working, thereby putting the laptop into sleep mode, the laptop begins to charge the battery.
                even checked it this way: I bring a neodymium magnet to the Hall sensor during operation - the screen goes out and the battery starts charging.
                Also, the laptop does not turn on without...
                04-02-2025, 02:45 AM
              • Zilicon
                AHL50/ ABL52 LA-C701P Rev:1.0 Turns on but turned off after few seconds
                by Zilicon
                Hearty greetings to everyone, trust you all are doing excellently well.
                Please, I have the above problem, the laptop turned on after the switch was activated but it will turns off in less than 2 seconds.
                The power stables in very rare case. Once it was stabled, everything works fine.
                Once the power switched is pressed, 5V and 3V were present.
                The things i have done:
                1. I have check for shorts on the board, but nothing. The board is short free
                2. Not a power switch problem, it behaves the same without the switch ...
                06-10-2024, 05:05 AM
