LG Flatron 1718S-BN has power but no video
  • De3rcr
    • Apr 2010
    • 94
    Hi Everyone,
    This is my first time posting about a problem I have. I've fixed 2 other lcd's by replacing caps and they work fine, but this one I don't know what to do next. I have this monitor that doesn't show any video when I connect it to a computer. I replaced the power supply caps with panasonic FM's but I still get the same results.
    I get 5.14v at the power supply output cable and the backlights seem to came on and stay on, but there is no video, the menu doesn't show when I push the button either.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: LG Flatron 1718S-BN has power but no video
    Excellent clear focused pictures. A+
    Test voltage regulators U101 and U102. It looks like U102 should be outputting 1.8V DC. I can't tell with U101 because of the angle of the photo. With U102, the last two digits are 18 which indicates 1.8V DC.
    --- begin sig file ---
    --- end sig file ---
    • bonney
      • Oct 2008
      • 74
      try reseating the screen cable on both screen and logic board also a good check of dry joints on logic board
      • PlainBill
        • Feb 2009
        • 7034
        Seriously good pictures, Dude. I have only one question. In the first picture one pants leg appears to be longer than the other. Is that a fashion thing, or just the camera angle?
        This is a strange problem. Here are a few things to check.
        1. Is the monitor detected when it is hooked up to a computer?
        2. You have indicated the "backlights seem to came (sic) on and stay on". Could you verify that? Usually there is some light leakage from the back of the LCD panel when the backlights are on.
        3. Check if the backlights are on when the cable from the power supply to the logic card is disconnected.
        4. There are two voltage regulators on the logic card - U101 and U102. Pins 1 and 3 are numbered, the tab is pin 2. With the logic card connected to the power supply, power supply on, etc, measure voltage from one of the mounting screws to each pin on each voltage regulator.
        5. Does the power LED react when you push the power button?
        PlainBill
        • De3rcr
          • Apr 2010
          • 94
          OK, got some more info
          The pant leg was just the camera angle.
          1. With just the power to the monitor I power it on and the light is green, when I plug in the vga cable it goes from amber to green(this is with the pc off). With it connected to the pc and power on its amber then when the pc is turned on it goes green, and when I shutdown the pc it goes back to amber.
          2. The backlights are working, I took the panel out of the plactic back panel and saw that the lights were on.
          3. The power button panel plugs into the logic board so I can't turn it on without the logic board pluged into the power board.
          4. Voltages without the vga cable attached
          U101
          pin 1: 0v
          pin 2: 3.31v
          pin 3: 5.18v
          U102
          pin 1: 0v
          pin 2: 3.84v
          pin 3: 5.16v
          It seems to act like it normally would but it doesn't show any video
          Thanks for your help
          • retiredcaps
            • Apr 2010
            • 9271
            U101
            pin 1: 0v
            pin 2: 3.31v
            pin 3: 5.18v
            U102
            pin 1: 0v
            pin 2: 3.84v
            pin 3: 5.16v
            U101 looks good. U102 pin 2 looks suspicious. If U102 is AS1117L-18, then I believe it should be 1.8V DC.
            • jetadm123
              • 2169
              U101
              pin 1: 0v
              pin 2: 3.31v
              pin 3: 5.18v
              U102
              pin 1: 0v
              pin 2: 3.84v
              pin 3: 5.16v
              Great pics and welcome to the forum! I suspect U101 is a 3.3V regulator and looks to be good. However, U102 seems a bit high. Please list the part numbers of U101 and U102.
              • De3rcr
                • Apr 2010
                • 94
                Here they are
                U101
                A1
                S1117L-33
                B0549
                U102
                A1
                AS1117L-18
                B0548
                • PlainBill
                  • Feb 2009
                  • 7034
                  Here they are
                  U101
                  A1
                  S1117L-33
                  B0549
                  U102
                  A1
                  AS1117L-18
                  B0548
                  Bingo!! U102 is toast. It should be 1.8 volts. No promises that you will have a working monitor if you replace it. Feeding 3.84 volts into an IC designed to take 1.8 volts tends to do BAD things.
                  PlainBill
                  • De3rcr
                    • Apr 2010
                    • 94
                    Anybody know where I can find this part or the locic board, I've searched the parts and can't find any?
                    Thanks for the help finding out what was wrong with it.
                    • jetadm123
                      • 2169
                      This is a common off the shelf part made by several manufacturers. Available through digikey.com. Part # 497-7308-1-ND
                      Select USPS First Class Ship for lowest cost shipping.
                      • De3rcr
                        • Apr 2010
                        • 94
                        Thanks jetadm123
                        I searched digikey with the part number off the chip and got no results(guess I was just searching wrong). will order and see if my soldering skills are good and post results.
                        • jetadm123
                          • 2169
                          Unfortunately, all the manufacturers have their own part numbers for the same part. In addition, there are several variations of this regulator:1.8V, 3.3V, etc. Therfore, it's not suprising that one has trouble finding the part.
                          • bonney
                            • Oct 2008
                            • 74
                            Pin 48 is the panel enable pin 84 is the reset might be worth checking them
                            • johnboy183
                              • May 2008
                              • 119
                              Just acquired one of these with exactly the same symptoms. Read this post and tried the two voltage regulators and the 1.8 was reading 3.84. Luckily I had another similar logic board with the same regulators so scavenged the 1.8 from it and used it to replace the faulty one and the monitor has now fully fired up and been running for several hours!
                              Really glad I saw this post as I was certainly scratching my head upto that point!
                              • PlainBill
                                • Feb 2009
                                • 7034
                                Good news. Glad it worked for you.
                                PlainBill
                                • shovenose
                                  Send Doge Memes
                                  • Aug 2010
                                  • 6575
                                  hey op did u ever get it fixed?
                                  • De3rcr
                                    • Apr 2010
                                    • 94
                                    I ordered the part Friday, should get it tomorrow or tuesday. Then I'm going to try to replace it. I've never replaced a part that small or a surface mounted chip, I've only replaced caps on power supply boards. Anybody have advice on how to go about it?
                                    • jetadm123
                                      • 2169
                                      You can use ChipQuik, or if you have a fine sharp pair of diagonal wire cutters, you can cut through each of the 3 legs. With your soldering iron, heat the tab and remove the chip with a pair of needle nose pliers. If you're having trouble melting the solder, try melting a small amount of lead/tin solder along the edge of the tab. Once chip is removed, with your soldering iron and a pair of pliers or tweezers remove each leg.
                                      • De3rcr
                                        • Apr 2010
                                        • 94
                                        Thanks jetadm123
                                        Digikey sent an email that it shipped friday. We'll see how long it takes to get here in FL. then I will try what you suggest.
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          09-06-2024, 05:59 AM
                                        • meraklinetx
                                          Asus Z97-a power cycle, no boot no cpu voltage
                                          by meraklinetx
                                          Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                          05-10-2023, 06:08 AM
